Topic: Combine two Arduino projects into one PCB with the Arduino codes combined. (Read 2493 times) previous topic - next topic
jaredm2195
would this code make sense for the task I need to complete.
when ( what ever button they pressed on the matrix keypad 3 by 4), play tone_=_Hz
here is the code:
# include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 3;
char hexaKeys[ROWS][COLS] = {
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
byte rowPins[ROWS] = {5, 6, 7, 8};
byte colPins[COLS] = {2, 3, 4};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
int notes[] = {440,294,330,349};
void setup(){
void loop(){
char customKey = customKeypad.getKey();
if (customKey == '1') {
   tone(9, notes[0]); // play tone (A4 = 440 Hz)
 else{
   noTone(9);
if (customKey){
Serial.println(customKey);
Grumpy_Mike
That is the sort of thing.
However the
Code: [Select]
else{
   noTone(9);
Bit means it will never produce any sound because all keys are not pressed at the same time and any unpressed key will stop the sound. Just leave that part out or use it for when no key is pressed.
jaredm2195
How would I use it for when no key is pressed? Would I just leave it the way it is or do something else? also, what would I do to play the sound? would I just put a piezo speaker in anywhere and it will just play?
jaredm2195
How do I use it for when no key is pressed? Would I just leave it the way it is or do something else? also, how can I hook up the dfplayer to work with this project. Also, I would need the schematic
polymorph
This seems like a topic for "Programming Questions" or "Project Guidance".
Steve Greenfield AE7HD
Drawing Schematics: tinyurl.com/23mo9pf - tinyurl.com/o97ysyx - https://tinyurl.com/Technote8
Multitasking: forum.arduino.cc/index.php?topic=223286.0
gammon.com.au/blink - gammon.com.au/serial - gammon.com.au/interrupts
Grumpy_Mike
Quote
Yes.
You could also make the tone for a fixed amount of time instead of leaving it to run forever. With a medium fixed time the tone would sound for say a second and yet when other keys are pressed it will override the current tone.
