Topic: Is my power supply sufficient enough? (Read 2421 times) previous topic - next topic
septillion
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
khimm19
#31
Apr 18, 2018, 11:24 am Last Edit: Apr 19, 2018, 03:53 am by khimm19
so this is my wiring diagram..
Robin2
Please display your image in your post so we can see it without downloading it. See this  Simple Image Guide
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
khimm19
yeah, no problem :)
i have posted my wiring diagram plss help me with the codes sir.. im planning to use the delay function but as i go forward searching.. i think it will not do the job
septillion
We're not going to write the program for you ;) So you have to make a start.
Delay() is a pore choice in most instances because it stops EVERYTHING dead in his tracks, including reading buttons etc. Might not really be a problem here but if you want to learn along the way, have a look at Blink without delay.
And base line, start by chopping up all you want to do do is small baby steps. Things like "start motor", rad button etc and try to make a complete description of what you want to do and/or make a flow diagram.
khimm19
im done with my project.. my problem now is my DC lock cant trigger when something heavy is pressured in it.. what i want to do with it is to carry something then drops suddenly.. does it do that?
Robin2
That sounds like a mechanical problem.
Please post a diagram that shows the actual arrangement of the lock.
Maybe (for security) it is a good idea that it cannot move when it is being abused?
...R
khimm19
...R
Tnx sir.. i have fix that issue..
i have an AC motor of the dryer from washing wachine and i am controlling it with arduino and relay.. my problem now is that its RPM is too fast (900RPM) and i want to reduce to 100RPM.. any suggestions sir on how i could do that?
Robin2
I have no idea.
...R
Coding Badly
i have an AC motor of the dryer from washing wachine ... RPM is too fast (900RPM) ... reduce to 100RPM
This would be a great moment to start a new thread on that much different topic.
But, there is an obvious answer: gear / belt reduction.
