Topic: LED brightness (Read 377 times) previous topic - next topic
fluxia
Hello, I am using different LEDs (red, yellow and green) in a project. Being my first project I have used 220ohm resistors as recommended in most tutorials. However all LEDs have different brightness, with the yellow being the brightest and the green the dimmest. Increasing the resistors values(I added two 10K resistors to the yellow leds) resolves the issue but I wander if there is anything else I need to consider before soldering.
I have used my multimeter to test voltage and current and I get the following values:
Voltage across LEDs:
green LED 1.988 V with 220 ohms
yellow LED 2.033 V with 220 ohms
Current:
yellow led:
- 10.85 mA with 220  ohms
- 2.39mA with 10220  ohms
- 1.34 mA with 20220 ohms
green led:
- 10.96mA with 220 ohms
- 2.37mA with 10220  ohms
- 1.33 mA with 20220  ohms
septillion
Not really, some leds are brighter than others. Especially with the 2V leds, green isn't that powerful.
Use fricking code tags!!!!
I want x => I would like x, I need help => I would like help, Need fast => Go and pay someone to do the job...
NEW Library to make fading leds a piece of cake
https://github.com/septillion-git/FadeLed
slipstick
I don't think your resistor values are what you think they are. Maybe 1K not 10K.
To get 1.34mA with 20220 ohms would need a supply voltage of nearly 30V.
Steve
fluxia
Thanks for pointing that out. Yes they are 1 K resistors.
