Topic: ANN: New "how to" for capacitive sensor shield (Read 3670 times) previous topic - next topic
tkbyd
At ArduCapSense.com, there is a shield giving you ($12 + p&p)....
8 Capacitive Sensed "buttons"
8 LEDs
There's a guide to using it, with much general material about capacitive sensing, newly published at...
http://sheepdogguides.com/arduino/art3capsen.htm
robtillaart
Won the ArduCapSense shield last year in a contest and found some time to write a simple Simon Game for it to test it. There are still a few TODO's but too busy with other thingies so I thought => publish . Use at own risk, Simon can be quite addictive :)
Code: [Select]
//    FILE: ArduCapSimon.pde
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.03
// PURPOSE: Simon Game for ArduCapSense shield - Arduino
// HISTORY:
// 0.1.00 - 2011-04-12 initial serial version of Simon Game
// 0.1.01 - 2011-04-14 added LED feedback
// 0.1.02 - 2011-04-14 added readKey - bug in returned values from shield :(
// 0.1.03 - 2011-04-18 tweaked autocallibrate value to 10 seconds
// TODO
// + add audio
// + add random seed (but for testing its nice to know the sequences :)
// Released to the public domain
// All disclaimers apply use at own risk
#include <CapSense.h>
// #include "pitches.h"
CapSense   cs1 = CapSense(10,9);
CapSense   cs2 = CapSense(10,8);
CapSense   cs3 = CapSense(10,7);
CapSense   cs4 = CapSense(10,6);
CapSense   cs5 = CapSense(10,5);
CapSense   cs6 = CapSense(10,4);
CapSense   cs7 = CapSense(10,3);
CapSense   cs8 = CapSense(10,2);
#define CAPSENSE_THRESHOLD  400
// TODO SHOULD BE IN CAPSENSE.H
#define LED1  16
#define LED2  15
#define LED3  17
#define LED4  13
#define LED5  18
#define LED6  12
#define LED7  19
#define LED8  11
#define AUDIO_OUT  14   // audio out pin
//int notes[] = {
//  NOTE_C4,
//  NOTE_D4,
//  NOTE_E4,
//  NOTE_F4,
//  NOTE_G4,
//  NOTE_A4,
//  NOTE_B4,
//  NOTE_C5 };
int ledArray[8] = {
  LED1, LED2, LED3, LED4, LED5, LED6, LED7, LED8 };
long total[8];
  // cs1.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1
  cs1.set_CS_AutocaL_Millis(20);
  cs2.set_CS_AutocaL_Millis(20);
  cs3.set_CS_AutocaL_Millis(20);
  cs4.set_CS_AutocaL_Millis(20);
  cs5.set_CS_AutocaL_Millis(20);
  cs6.set_CS_AutocaL_Millis(20);
  cs7.set_CS_AutocaL_Millis(20);
  cs8.set_CS_AutocaL_Millis(20);
  // INIT AUDIO
  pinMode(AUDIO_OUT, OUTPUT);
  // INIT LEDS
  for (int i=0; i< 8; i++) pinMode(ledArray[i], OUTPUT);
  for (int i =0; i< 8; i++) digitalWrite(ledArray[i], LOW);
  // SEED RANDOM GENERATOR
  // TODO
  playSimon();
#define MAXSIMON 100
int level = 1;
int delayDividor = 1;  // TODO so higher levels go faster ...
byte simonArray[MAXSIMON];
byte playerArray[MAXSIMON];
void playSimon()
  // FORCE RECALLIBRATION EVERY LEVLEL
  cs1.reset_CS_AutoCal();
  cs2.reset_CS_AutoCal();
  cs3.reset_CS_AutoCal();
  cs4.reset_CS_AutoCal();
  cs5.reset_CS_AutoCal();
  cs6.reset_CS_AutoCal();
  cs7.reset_CS_AutoCal();
  cs8.reset_CS_AutoCal();
  // START
  Serial.print("SIMON GAME, level : ");
  Serial.println(level);
// animation
//  for (int i=8; i> 0; i--)
//    int led = ledArray[i-1];
//    digitalWrite(led, HIGH);
//    delay(100);
//    digitalWrite(led, LOW);
//    delay(100);
//    Serial.print(i, DEC);
//  Serial.println();
//  delay(500);
  // SHOW LEVEL by LEDS
  for (int i=1; i<=level && i<=8; i++)
    digitalWrite(ledArray[i-1], HIGH);
    digitalWrite(ledArray[i-1], LOW);
  // GENERATE SIMONARRAY
  int rnd = 4 + level/3;
  rnd = constrain(rnd, 4, 8);
  for (int i=0; i< level; i++)
    simonArray[i] = random(rnd) + 1;
  // PLAY SIMONARRAY
  Serial.println("listen carefully");
  int del = 510 - level * 10;
  del = constrain(del, 100, 500);  // level 30 - level 1
    int led = ledArray[simonArray[i]-1];
    delay(del);
    delay(100);
    Serial.println(simonArray[i], DEC);
  // PLAYERS ARRAY
  while(Serial.available()) Serial.read(); // flush serial buffer
  Serial.println("now it's your turn");
    int x = readKey();
    Serial.print("X : ");
    Serial.println(x);
    playerArray[i] = x;
    //while(Serial.available() < 1);
    //playerArray[i] = Serial.read() - '0';
    int led = ledArray[playerArray[i]-1];
    delay(200);
    delay(100);
  // COMPARE AND INCREASE / DECREASE LEVEL
  bool OK = true;
  for (int i=0; i< level && OK; i++)
    OK = (simonArray[i] == playerArray[i]);
  if (OK) level++;
  else level--;
  level = constrain(level, 1, MAXSIMON);
  // TODO COMPARE TO HIGH SCORE  (eeprom?)
int readKey()
  int highestTotalIndex = 0;
  do
    total[0] =  cs1.capSense(30);
    total[1] =  cs2.capSense(30);
    total[2] =  cs3.capSense(30);
    total[3] =  cs4.capSense(30);
    total[4] =  cs5.capSense(30);
    total[5] =  cs6.capSense(30);
    total[6] =  cs7.capSense(30);
    total[7] =  cs8.capSense(30);
    for(int i = 1; i < 8; i++)
      if (total[i] > total[highestTotalIndex])
        highestTotalIndex = i;
  while (total[highestTotalIndex] < CAPSENSE_THRESHOLD);
  Serial.print("highest  : ");
  Serial.println(total[highestTotalIndex]);
  // TODO recallibrate
  return highestTotalIndex+1;
// END OF FILE
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
