Topic: 4 channel relay with 4 buttons (Read 210 times) previous topic - next topic
r_dahiya
Apr 19, 2018, 07:27 pm Last Edit: Apr 19, 2018, 07:59 pm by r_dahiya
hi, I have a 4 channel relay and I want to use it for switching with arduino uno. I have written a code for it which is as under
Code: [Select]
#define reone 7 //relay no. 1
#define retwo 6
#define rethree 5
#define refour 4
#define sone A2 // switch no. 1
#define stwo A3
#define sthree A4
#define sfour A5
int val1=0;
int val2=0;
int val3=0;
int val4=0;
pinMode (reone, OUTPUT);
pinMode (retwo, OUTPUT);
pinMode (rethree, OUTPUT);
pinMode (refour, OUTPUT);
pinMode (sone, INPUT);
pinMode (stwo, INPUT);
pinMode (sthree, INPUT);
pinMode (sfour, INPUT);
void loop(){
offline();
void offline(){
relay1();
relay2();
relay3();
relay4();
void relay1(){
val1 = digitalRead(sone); // read input value and store it
// check whether the input is HIGH (button pressed)
if (val1 == HIGH) {
digitalWrite(reone, HIGH); // turn relay ON
digitalWrite(reone, LOW);
void relay2(){
val2 = digitalRead(stwo); // read input value and store it
if (val2 == HIGH) {
digitalWrite(retwo, HIGH); // turn relay ON
digitalWrite(retwo, LOW);
void relay3(){
val3 = digitalRead(sthree); // read input value and store it
if (val3 == HIGH) {
digitalWrite(rethree, HIGH); // turn relay ON
digitalWrite(rethree, LOW);
void relay4(){
val4 = digitalRead(sfour); // read input value and store it
if (val4 == HIGH) {
digitalWrite(refour, HIGH); // turn relay ON
digitalWrite(refour, LOW);
the output of this code starts flickering, someone please can modify this code so that flickering may be removed and also is there any scope so that the length of code can be decreased...thanks
Robin2
To make it easy for people to help you please modify your post and use the code button </>
Code: [Select]
so your code looks like this and is easy to copy to a text editor. See How to use the Forum.
ALSO, please use the AutoFormat tool to indent your program code consistently for easier reading.
You say that the output starts flickering - does that mean that a relay goes on and off rapidly?
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
r_dahiya
Yes, it goes on and off rapidly
Code: [Select]
...R
Robin2
See how much easier it is to read your code when it is indented and has some whitespace between the functions. Use the AutoFormat tool.
Code: [Select]
#define retwo 6
#define rethree 5
#define refour 4
#define stwo A3
#define sthree A4
#define sfour A5
int val1=0;
int val2=0;
int val3=0;
int val4=0;
void loop(){
    offline();
void offline(){
    relay1();
    relay2();
    relay3();
    relay4();
void relay1(){
    if (val1 == HIGH) {
void relay2(){
    if (val2 == HIGH) {
void relay3(){
    if (val3 == HIGH) {
void relay4(){
    if (val4 == HIGH) {
I suspect your problem is due to switch bounce. Do you have external pull-down (or pull-up) resistors on the switch pins. if not the easiest thing is probably to use pinMode(pin, INPUT-PULLUP); to activate the internal pull-up resistors. Then wire your switches so that they pull the pin to GND when closed. Also note that that will mean LOW signifies the switch is closed.
It would also be a good idea to have ashort interval between successive readings of the switches. Have a look at the demo Several Things at a Time
If you want the relay to stay in position until the switch is pressed a second time then you need different code. Have a look at the State Change example that comes with the Arduino IDE.
...R
