Topic: Manage ON-OFF Led with 24 channel PWM LED (Read 133 times) previous topic - next topic
gianni49
I have a 24-channel 12-bitl pwm led driver connected to the Arduino UNO R3 to manage 24 normal LEDs in ON or OFF states. When I set channel n to the ON state, when I change the channel and select channel m and set it to ON, the led connected to channel n goes into the OFF state. How can I keep the status of the channels static? It's possible to do it? Forgive my imperfect English. Thank you.
slipstick
Can you post please the specification of your "24-channel 12-bitl pwm led driver" or a link to it?
The code you are using to drive it and a diagram showing how everything is connected would also be useful.
Steve
gianni49
The board to manage the  Led is Adafruit 24-Channel 12-bit PWM LED Driver - SPI Interface - TLC5947. The hardware work fine. I choose an address and send the led lighting command and the LED lights up.
I leave the LED on and I try to turn on another LED, but when I send the ignition command the previous LED goes off. I would like the previously lit LED to remain on.
Here is my sketch
gianni49
Problem?
substitute lines og sketch :
#define data  4
#define clock 5
#define latch 6
with:
#define data  10
#define clock 11
#define latch 12
gianni49
II do not know how, but the problem has solved itself.
