Topic: Automate window blinds (Read 320 times) previous topic - next topic
Transporter007
Hi Everybody,
I am new to working with arduino and I am in need of your help.
I am trying to automate my windows blinds and the tools which I am trying to accomplish this task is:
1. Blynk mobile App
2. NodeMCU
3. 360 degree continous servo motor (Luxorparts Servo 360° 5,5 kg - Modell nr: DS04-NFC)
4. IFTTT
5. Google home
I have so far got it to work with the blynk app so that I can controll the servo, but the challenge I am facing  right now is that I don't know how to have the servo to spin for lets say 10 seconds and then hold that position.
I have searched all over the web but can't seem to find anything that could point me in the right direction.
Any help is highly appreciated.
here's the code:
Code: [Select]
/* Comment this out to disable prints and save space */
#define BLYNK_PRINT Serial
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <Servo.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "Blynk authentication code";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "name of wifi network";
char pass[] = "wify password!";
Servo servo;
BLYNK_WRITE(V3) {
servo.write(param.asInt());
// Debug console Serial.begin(115200);
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8442);
servo.attach(15); // 15 means D8 pin of ESP8266
Blynk.run(); // You can inject your own code or combine it with other sketches.
Please understand I am totally new, and the code above is not something I have put together by myself, a kind sole shared that.
Thank you
Edgar128
when a pulse of 1500 μS width is given, the servo shaft holds position at 0 degrees without moving. A CR servo in a neutral position will hold shaft stationary. When the pulse width is reduced from the neutral position, (say 1400 μS ) the shaft starts to rotate in anti-clockwise direction.
