I think the latest version I sent was sper7 in post #116.
It would be interesting to prod around with an oscilloscpe if you've got one.....
higher flow rate of dielectric with a low viscosity fluid could help - we've been here before!
Allan
sper7 is the one with the current control correct? I have not yet implemented that.
I would LOVE a scope, but I dont have one
I dont know what had happened to my pulses, but they were way out of wack. I changed the software so that the pulse pin is now toggled in hardware (i had been writing it high or low in an ISR())....that seems to have fixed it and changed the operation of the system for the better.
I don't think higher flow rate would help, higher pressure might, but more pressure tends to move the electrode around....that leaves a thinner DE, I still intend to go back to kerosene, I just keep getting caught up with other stuff.
This machine has consistency worked better right when I start it and then over a few hours, just fades out. I now think this is the result of the magnetism. I am not clear as to how it is magnetizing, I thought you needed a current carrying conductor wrapped around a core in order to magnetize? When it shat out on me last night, I moved the part off center and started a new hole, it seemed to work right away despite the magnetism and it has run reasonably well for several hours...the parts are still magnetized, but not as much....I don't know what this all means, any theories are welcome.
