Topic: MIDI plus USB serial (Read 8615 times) previous topic - next topic
WilliamK Govinda
I was playing around with a code another user contributed, and created a VST plugin that reads the Serial data from our Beat707 unit and outputs Midi Notes. It works perfectly. Now I can also do a .exe app that does the same. Right now I'm doing it oriented to Beat707, but the idea is to make it open-source and based on Juce, so anyone can use it for their arduino midi projects without the need of a midi interface.
Wk
audioguytodd
Wk
That would be VERY useful WilliamK.  :)
WilliamK Govinda
Here's a quick video of energyXT loading the VST file that connects to Beat707 via the USB cable. No MIDI devices were used for this example, but Beat707 is sending regular MIDI data via the Virtual Serial connected thanks to the FDI chip. Resuming: no hardware or software changes. (at least no big software changes)
http://www.youtube.com/watch?v=l0JL9lz6kvI
During the Beat707 startup, it starts at 57600bps, sends 4 bytes of a code to the serial output, waits 1 second, and if nothing is received, it re-starts the serial port at 31250bps and enables the midi connection.
The VST file checks all Serial ports, for each port, it waits 2 seconds, so the Arduino has time to reboot and send that 4 bytes of code above, and if the code the VST reads is ok, it sends an OK message back so the Arduino goes to USB mode. After that, they "talk" to each other. ;-)
Wk
audioguytodd
That looks great!!!! Please announce it in this forum when you release the VST. I would love to give it a try!!! :)
WilliamK Govinda
The code is pretty much done, I just posted in a new thread.
http://arduino.cc/forum/index.php/topic,58334.0.html
Now I need to figure out the Stand-Alone version. ;-)
Wk
