Topic: HttpClient post request return only -1 not 200.  (Read 985 times) previous topic - next topic
kotran
Hello
I'm sending Image byte data to server.
String payload is like
value=255,216,255,224,0,16,74,70,73,70,0,1,1,1,0,0,0,0,0,0,255,219,0,67,0,12,8,9,11,9,8,12,11,10,11,14,13,12,14,18,30,20,18,17,17,18,37,26,2
        HTTPClient httpClient;
         httpClient.begin(targetUrl);
         httpClient.addHeader("Content-Type","application/x-www-form-urlencoded");
         int httpCode = httpClient.POST(payload);
        Serial.println("httpcode");
         Serial.println(httpCode);
        httpClient.end();
but httpCode is always -1
and I checked server's logs. It didn't reach.
below is node js server that image should arrive.
      app.post('/pic',function(request,response){
J-M-L
Don't post snippets...
What is in targetUrl? Is that a correct address? Can you reach it from your computer?what happens if you submit your POST?
How is the network configured on your arduino?
What does httpClient.begin(targetUrl); return?
Hello - Please do not PM me for help,  others will benefit as well if you post your question publicly on the forums.
Bonjour Pas de messages privés SVP, postez dans le forum directement pour que ça profite à tous
PaulS
Quote
In the stupidest possible way, apparently.
Why on earth would you send binary data as text?
kotran
I thought firstly sending byte data seperated by comma then, on server, I could make string data to image byte .
targetUrl is http://camerauploading.herokuapp.com/pic and work find with postman test(sending sth with post)
Node js server is as below
and for postman post Test. it comes to pic come logs and request method is logged as POST .
but once I request post. I didn't reach here and httpCode result is -1 . not 200
   console.log("pic come");
  console.log(request.method);
   if (request.method === 'POST') {
PaulS
Quote
Are the bytes separated by commas in the image file? NO.
There must be some part of "POST ALL OF YOUR CODE" that you find difficult to understand.
J-M-L
See #1 and provide feedback to all questions
