Topic: Could I write a program for control 8 arduino devices at the same time? (Read 339 times) previous topic - next topic
frank197662
Could I write a program for control 8 arduino devices (MEGA 2560 R3 )  on pc via rs 232 , that mean is control 8 com port at the same time?
larryd
A Mega has 4 hardware serial ports.
The most number of Megas I have run (at the same time) on a PC is two, but then again I only have two Megas.
Each Arduino you plug into a USB port will have a different COM number.
No technical PMs.
The last thing you did is where you should start looking.
TomGeorge
Welcome to the Forum.
What is the application that needs 8 Megas?
Thanks.. Tom.. :)
Everything runs on smoke, let the smoke out, it stops running....
Robin2
Have you considered connecting one Mega to your PC and connecting the other Megas to the first one rather than to the PC?
If you tell us all about the project you are trying to create it will be much easier to help.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
PaulS
You have our permission to.
That you had to ask, though, makes me suspect that the answer is that no, you can't.
frank197662
Thank you
frank197662
My project is that my clinet has 8 buttons, if I put 1 of the button then send message to server, Server receive the button message then send message to arduino by using RS232 and let the pin to low for control machine's status. Totat 48 clients.
Paul_KD7HB
Welcome to the Arduino forum, Frank.
A block diagram of your project will help clarify what you are doing.
Paul
Robin2
What sort of machines are you talking about? That can affect the type of control system that is appropriate.
How far apart are the 48 machines? Why not just use a single Mega for the complete job?
Do the 48 Arduinos have to send data back to the server?
Also, note that an Arduino does NOT use RS232 voltage levels - they can damage an Arduino. If your PC produces RS232 voltage levels then you need a MAX232 chip to convert to the Arduino's TTL voltage levels.
...R
lastchancename
Signalling like RS485 is not restricted to serial comms.
You could use it to carry the switch contacts to the input pins of the Arduino's.
Experienced responders have a nose for laziness, (they were beginners once)... Sure, there are trolls, know-it-alls, and pretenders - but the help you'll get here is about as good as it gets - if you try to help youself!.
