Topic: How to detect frequencies for male and female  (Read 152 times) previous topic - next topic
xtamii94
Apr 25, 2018, 11:12 am Last Edit: Apr 25, 2018, 11:13 am by xtamii94
Hello
I had done this code to distinguish between male and female by voice. If the frequency located between 65 Hz and 180 Hz which is for male, the lock will not open. If the frequency was from 150 Hz to 255 Hz which is for female, the lock will be opened. If the frequency located in overlap range 150 to 180, IQR should be performed. The value for Female IQR is more than 0.07 and for male is less than 0.07.
The question is, I didn't perform IQR method, instead i used EMA which is smoothing filter.
When i run the code it always gives the result as female. Can somebody figures why ?! also i done another code for iqr method but it is not working . The codes is below :
EMA method:
// include the library code:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
//Global Variables
int sensorPin =
5;    //pin number to use the ADC
int sensorValue = 0;  //initialization of sensor variable, equivalent to EMA Y
float EMA_a = 0.3;    //initialization of EMA alpha
int EMA_S = 0;        //initialization of EMA S
int filter = 0;
const int LockPin = 7;
// set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
   Serial.begin(115200);              //setup of Serial module, 115200 bits/second
  EMA_S = analogRead(sensorPin);     //set EMA S for t=1
  pinMode(LockPin, OUTPUT);
   digitalWrite(LockPin, LOW);
  // set the cursor to column 0, line
  lcd.setCursor(0, 0);
  // print the number of seconds since reset:
   lcd.clear();
  lcd.print("SAY A WORD");
sensorValue = analogRead(sensorPin);              //read the sensor value using ADC
  EMA_S = (EMA_a*sensorValue) + ((1-EMA_a)*EMA_S);  //run the EMA
  filter = sensorValue - EMA_S;                   //calculate the high-pass signal
  Serial.println(filter);
  delay(20);                                //20ms delay
if (abs(filter)>200 && abs(filter)<1000)
  lcd.clear();
  lcd.print("PROCESSING...");
  delay(5000);
  lcd.clear();
  lcd.print("Female,Access is");
   lcd.setCursor(0, 1);
   lcd.print("granted");
   digitalWrite(LockPin, HIGH);
   delay(50000);
else if (abs(filter)>1000 )
  lcd.clear();
  delay(5000);
  lcd.clear();
  lcd.print("Male, Access is");
   lcd.print("denied");
  delay(5000);
IQR method:
// including the library
#include "iqr.c"
//Initialize variables
const int micPin = A5;
int soundArray[500];
int a=3.3097994987, b= 3.31107769; //voltage equivalent to 165(a) and 180(b) Hz frequency
int i;
float iqrVal;
//Connections of LCD pins with Arduino board
//Input and output pins are assigned
 pinMode(micPin, INPUT);
//set your COM accordingly
  Serial.begin (9600);
//16 columns and two rows
lcd.begin(16, 2);
  // set the cursor to column 0, line 1
//Record the voice in soundArray
  for (int i = 0; i < 500; i++)
    delay(10);
    int micValue = analogRead(micPin);
    soundArray = micValue;
//Calculate IQR only when frequency is between 165 to 180 Hz
  if (a < soundArray < b)
//finding IQR
    iqrVal = iqr(soundArray);
  if(iqrVal>0.07){ //FEMALE
    digitalWrite(LockPin, HIGH); //Lock is opened
    lcd.print("Female, Acess is granted");
  else{ //MALE
  digitalWrite(LockPin, LOW);  //Lock is not opened
  lcd.print("Male, Acess is denied");
  delay(10);
PaulS
Quote
And if the frequency is between 150 and 180, the lock will do the holey-pokey?
Code: [Select]
You seem to think that you are going to learn something from a single analog reading. Not going to happen.
Code: [Select]
Pretty stupid initial values for integer variables.
Code: [Select]
I'm pretty sure that the address of the array will be greater than 3. I'm positive that both true and false are less than 3. I'm equally positive that this whole block of code is useless.
