Topic: Calling all ESP experts (Read 841 times) previous topic - next topic
Fathead
I am trying to conect 2 esp8266 devices together through a router. What i want to do is have a reed switch on a door so an open closed signal is sent when the door is opened or closed, through the magical system of WIFI through my router to another esp8266 where the signal will operate a servo with a pointer on it. Door open, servo points to open etc.
I am also wanting to conect a dht22 so i can get the outside temp/humidity buts thats an add on.
The question is how do you send the signal from the reed switch to the other esp8266 i am at a loss at doing this. I don't want a broker or a MQTT just a simple indication of my door, (my door is attached to a shed in the garden)?
I have wriiten code that works perfectly on one esp8266 device but that is all conected together i just need to seperate the devices over WIFI.
Any help will be greatly recieved or guidance pointing me in the right direction.
Juraj
use WiFiServer and WiFiClient and send with client to server what you want
You can't write an Arduino sketch if you didn't learn programming. Not the language, but the concepts of programming - algorithms and data types.
Fathead
the wificlient and server that you mention are the libaries that you include at the top of the code
PaulS
They are also the names of example sketches.
Fathead
Thank you for the respose I have seen them examples and i have succesfully connected to my home network  on both esp's, i think im being dumb as i still can't figure how to send a reed output from one esp to the other!
PaulS
The ESP can be a server or it can be a client. Servers can't push data. Clients can pull data. In the process, they can make a server aware of data.
So, the thing acquiring data that the other needs to know needs to be a client. The one with the need to know needs to be a server. The client makes a GET request, with the data that server needs to know.
Juraj
not a GET request, please. nice plain telnet is good. start a server at port 2323 and connect to it from client and send what you want and process it on server and eventually send something back to client.
you can test the server with telnet client (telnet <ip> 2323)
PaulS
Why tie up a connection, when the only information that needs to be exchanged involves the door being opened or being closed? How often is THAT going to happen?
Juraj
#8
Apr 25, 2018, 05:02 pm Last Edit: Apr 25, 2018, 05:02 pm by Juraj
nothing is tied up. the client can close the connection after the event. the server must listen all the time.
for this simple task RF communication would be better
PaulS
Quote
nothing is tied up.
So, the ESP can support an unlimited number of connections. That's news to me.
Juraj
I do not understand. How does my recommendation  imply unlimited connections?
PaulS
#11
Apr 25, 2018, 06:24 pm Last Edit: Apr 25, 2018, 06:24 pm by PaulS
If there are a limited number of connections (like the Ethernet shield can only handle 4 simultaneous connections), and you use one of them for a telnet session, so that you can be told twice a day that the door opened or closed, then that connection is not available for any other use. Hence it is tied up.
Quote
nothing is tied up.
It that one connection is nothing, this implies, to me, at least, that it isn't 1 of 4. Rather, it is one of so many that one doesn't matter.
So, which is it? Are you tying up one of a limited number of connections, where it could matter, or one of so many that it doesn't matter?
Juraj
I do nothing, I only recommend using the simplest way.
esp8266 can handle 5 sockets. This project needs one socket on the client esp8266. On the server one socket is the listening socket a second socket is the current client. server side sketch can refuse more clients by simple stopping the incoming connection.
the OP can decide if he lets the client connection alive or closes it after every event. if the client closes the connection, the server side closes it too. I would close the sockets after the event in this case.
6v6gt
I guess that at least the door switch part is to powered by battery.
Anyway, even if not, probably the best configuration is to have the ESP8266 which monitors the door switch configured as a web client. When the door switch changes state, it wakes up and posts (using HTTP POST or HTTP GET) the status update to the web server (another ESP8266). After that it goes back to sleep. The ESP8266 configured as a web server must run all the time, waiting for status change messages from the ESP8266 monitoring the door switch and act on them issuing alarm calls etc.
If you have an existing wifi network, then it is probably best to integrate the two ESP8266 devices in your existing wireless lan. If not, you can make the ESP8266 which is designates as the web server also into an Access Point (AP mode) which effectively creates its own private wlan.
The mechanism is simple. It is exactly analogous to using your web browser to post a message in this thread. Your browser is the web client and at forum.arduino.cc there is a web server running which accepts your post.
Juraj
#14
Apr 25, 2018, 07:50 pm Last Edit: Apr 25, 2018, 07:57 pm by Juraj
why web? why HTTP? plain socket communication will do it
