Topic: Sending data from Datalogger to Arduino (Read 344 times) previous topic - next topic
luciocr
Hello everyone! I would like to know if it is possible to transfer data from datalogger (CR200) to an Arduino UNO, without using communication protocols (like I2C, UART)! I want to do it just connecting the wires (like we connect TX (from one Arduino) ---> RX (to another) and RX ---> TX ) between the UNO and the CR200 ! How could I do this?
luciocr
GolamMostafa
#2
Apr 27, 2018, 03:58 pm Last Edit: Apr 28, 2018, 03:02 am by GolamMostafa
This link says that the communication link is RS232.
In that case case, you need a RS232 to USB converter cable and connect it diretly with PC. The data logger should be accompanied with a Software Package.
If you want to collect the data into your Arduino, you need RS232 <-----> TTL Converter chip like MAX232; then, connect the TTL level signals with the UART port (0, 1) of Arduino UNO. You need to write your data acquisition/processing routines using Arduino IDE.
Thanks,
larryd
Quote
If the CR200 expects a communication protocol, then no.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
