Topic: Data plotting in Excel sheet from the Arduino UNO (Read 821 times) previous topic - next topic
7896792575
Apr 28, 2018, 08:52 pm Last Edit: Apr 28, 2018, 09:28 pm by surbyte
I am trying to Plot Transfer Characteristics of NPN Common Emitter BJT . collector emitter voltage  versus collector current in X-axis Versus Y-axis. Whileusing voltage and current of step 30, Then it gives the correct values in Excel sheet and when we reduced or increased the step size of 30, it gives very large error. Can anybody tell why it is happening? if it gives correct value at step of 30 then it should also give correct value at another step size. i am attaching program.
Code: [Select]
#include <rExcel.h>
//int           outputTiming = 1000;
long          idx = 1;
char          value[16];
int ini=0;
//float rnd;
rExcel        myExcel;
int pwmOut1=3;
int pwmOut2=11;
int  i,readValue1,readValue2,readValue3;
float VB[30],VBE[30],IB[30],VCE[30],IC[30];
myExcel.clearInput();
 //randomSeed(analogRead(5));
pinMode(pwmOut1, OUTPUT);
pinMode(pwmOut2, OUTPUT);
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(A2, INPUT);
 analogWrite(pwmOut1,204);
if (ini==0){
 idx=1;
  //analogWrite(pwmOut1,204);
for (i=ini; i<=255;)
 analogWrite(pwmOut2,i);
readValue1=analogRead(A0);
 readValue2=analogRead(A1);
  readValue3=analogRead(A2);
 VBE[i] = (5./1023.)*readValue1;
 VB[i] = (5./1023.)*readValue2;
 VCE[i] = (5./1023.)*readValue3;
 IB[i] = (VBE[i]-VB[i])*(1./660.);
 IC[i]=330*IB[i];
  myExcel.writeIndexed("bjtchar", idx, 1, idx);
   myExcel.writeIndexed("bjtchar", idx, 2, VCE[i],2 );
   myExcel.writeIndexed("bjtchar", idx, 3, IC[i],2 );
Serial.println(i);
i=i+30;
 idx++;
else {
 ini=i-30; idx--;
 for (i=ini; i>0;)
 IC[i]=330*IB[i];
  //myExcel.writeIndexed("bjtchar", idx, 1, idx);
   Serial.println(i);
i=i-30;
 idx--;
Moderator: Code tags added.
jremington
Please edit your post to add code  tags, so that it
Code: [Select]
looks like this.
See the "How to use this forum" post.
Quote
Give details, please.
Post a link to where you downloaded the Excel library.
larryd
Show us a good schematic of your circuit.
Show us a good image of your wiring.
No technical PMs.
If you are asked a question, please respond with an answer.
If you are asked for more information, please supply it.
If you need clarification, ask for help.
7896792575
Actually i have downloaded a software named excel commander which is interfaced with Arduino and Excel 2013
ieee488
So what?
