Topic: Making an arduino wall power supply? (Read 5953 times) previous topic - next topic
polishdude20
So how would I go about making a power supply for the arduino that connects to the wall?
RuggedCircuits
Really?
You don't just want to buy one of these?
http://www.mpja.com/prodinfo.asp?number=18469+PS
The Arduino Drum Machine: MIDI development system with 14-track MIDI drum machine sequencer / groove-box software
polishdude20
Really?
no, cause then what will I learn?
RuggedCircuits
OK....then build this :)
http://www.onsemi.com/pub_link/Collateral/TND330-D.PDF
A more traditional (and much simpler) design involves a transformer, rectifier, and filter. Maybe start here?
http://www.repairfaq.org/sam/samschem.htm#schlpi
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
retrolefty
Really?
We all applaud learning opportunities. However because such a power supply has to wire to 120 or 220 vac outlet power, it's not a real safe candidate projects for those inexperienced with electrical safety requirements. Most small wall wart power modules are well insulated and have various approval ratings for safe operation. I would recommend you limit your learning experience to projects that only use DC voltages up to 24vdc or less.
Lefty
polishdude20
Really?
Lefty
ha! you know I'm not gonna take your word for it right? I'm pretty confident in my safety, I'm not some stupid kid.
polishdude20
wait a second! I found my old Dlink router wall adapter and its rated output is 5v 2.5 amps. WOuld the 2.5 amps matter for the arduino? if so then what can I do to lower the current?
retrolefty
Quote
LOL  I was once. I was sticking wires into power outlets at the tender age of 10. I though I could make a great electromagnet by winding ten turns of number 12 gauge wire around a large nail and stuck the wire ends into the plug, lots of smoke, small flame, blister on fingers. I had to then quickly find out how to change a screw in fuse on the service panel before my folks found out, luckly there were a few spare fuses on top of the panel.
Have fun, do be safe and let us know what you come up with.
Lefty
polishdude20
Quote
Lefty
lol! well thanks for nto being all grown u on me and stuff but yeah I'm 17 so I think i've learned enough to know how to handle a wall outlet, but ye I tried my dlink adapter 5v 2.5A and it works to blink an LED but not my LCD
retrolefty
Quote
I would think 2.5 amps would be more then enough for a LCD?  Are you sure there is not some other problem? Got a link to the LCD?
Lefty
Magician
With all my respect to the author of this post,
and participants,
especially: RuggedCircuits
it's not a compliment, he give an answer.
And I think good answer.
So what is all about?
A power suply or ardino + power suply?
just buy one (power supply) on a market, because in IMHO it will cost more to buid one.
polishdude20
and participants,
well actually It is free to build one for me possibly because in my electronics class we have tons of parts and the teacher usually lets us use them for free. And also to the other guy my answer is that I think since it's 5 volts that it's not working. I read that the arduino needs at least around 6-9 volts externally so it can lower the voltage down to 5. But with it already at 5 it wont work.
CrossRoads
If you really want to build one, here are classic linear regulator designs, I built many of these for my digital and analog projects over the years.
TO-220 style with heat sink for small loads, the bigger pancake style screwed to chassis (with mica insulator) for higher currents.
(unable to  upload files, error message saying upload file are is full ?? reported to admin)
Magician
Yes, CrossRoads is right, the simplest power supply. It could be even simplier
if no 7805 chips in, as arduino has chip on a board : MC33269D
So what is your budget, have more money I can provide you details how to build switching
power supply unit, high grade, military special requirement,
you can launch it on a rocket:
temp - -40 - 150C
vibration - more than 20g
x-ray resistive;
Or you ca buy Chinese one for 2$   :)
keeper63
...then...
/emphasis mine/
Listen - not meaning any disrespect here; I'm double your age and then some, but I remember what I was like when I was 17 - I was a "stupid kid". This isn't to say I was ignorant, nor is it to say I didn't know anything or have any reasoning skills. What I want to convey is that someday, you're going to look back on being 17 and say to yourself "damn, maybe I didn't know everything after all" - and perhaps on thinking that you'll remember these comments.
Mains power isn't something to casually mess with; most adults don't even understand the difference between neutral and ground. One wrong move and you might find yourself in the hospital, or possibly the morgue.
The fact that you think you must somehow lower the current output of a power supply tells me you are no where near ready to tackle a mains powered power supply. Get some more knowledge under you belt, then return to the idea.
/stay safe...
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
