Topic: Infrared Receivers and Transmitters? (Read 2042 times) previous topic - next topic
polishdude20
So do all IR receivers have that square type of casing around them or can they also looks just like regular LED's?
How would I differentiate between a receiver and a transmitter?
RuggedCircuits
Quote
They probably do not look like regular LED's. You have to distinguish between an "IR logic decoder" and a much simpler "IR photodiode" or "IR phototransistor". An IR logic decoder (like the TSOP4838) has an IR photodiode inside it, plus a whole bunch of additional circuitry to pulse a logic output low when infrared energy is detected at a specific frequency (38 kHz). It also generally has 3 pins because it needs 2 power pins (e.g., +5V and 0V) in addition to its logic output.
The simpler IR photodiode/transistor are just passive devices; they aren't sensitive to any particular frequency, they don't have any additional circuitry, and they only have 2 pins. You definitely want the "IR logic decoder" if you're going to be decoding infrared remote controls.
The Aussie Shield: breakout all 28 pins to quick-connect terminals
polishdude20
Quote
could the IR logic decoder be taken out of a VCR player or a common DVD player?
Magician
Yes. It will provide digital output without a decoding.
polishdude20
wait so if I take out an IR receiver with 3 pins from a dvd player or vcr then it wont be good for what im doing?
Schmidtn
Is it my turn?
So, what are you doing?
polishdude20
Is it my turn?
I want to copy an IR signal to the arduino EEPROM and then transmit it back through an IR transmitter.
Schmidtn
Ah, I see.  Why did you make two posts about this, it's kind of confusing.
A 38kHz Infrared Receiver Module from RadioShack is around 4 bucks and will work.
http://www.radioshack.com/product/index.jsp?productId=2049727
I'm not sure if a 38K module from an old TV or DVD player will work, but if you've already salvaged one and it is not working you might try to see if there is a filter over the lens.  Taking that off might get your module working but it will also open you up to false readings.  Best bet is just to get a new 38K IR module.
