Topic: PID - 4 motors car (Read 523 times) previous topic - next topic
rubzir
May 02, 2018, 11:25 am Last Edit: May 02, 2018, 11:28 am by rubzir
I'm building a line follower car robot with 4 motors (2 each side. each 2 motors get the same input).
I was following the instructions I read from https://www.pololu.com/docs/0J21/7.c, but this code is for 2 wheels car. I tested it on my car but it doesn't turn as I expected
My robot i capable of 360 degrees turn but this PID algorithm is not using negative values
Do you have an example of how to modify the PID algorithm  or example, so it will be good for 4 wheels?
signed int position = read_line(sensors,IR_EMITTERS_ON);
int proportional = ((int)position) - 2000;
int derivative = proportional - last_proportional;
integral += proportional;
last_proportional = proportional;
int power_difference = proportional/20 + integral/10000 + derivative*3/2;
const int max = 60;
if(power_difference > max)
   power_difference = max;
if(power_difference < -max)
   power_difference = -max;
if(power_difference < 0)
   set_motors(max+power_difference, max);
   set_motors(max, max-power_difference);
Thanks,
vinceherman
If your 4 motor/4 wheel car steers like a skid steer, then it should operate the same way as a 2 motor 2 drive wheel car (usually with a caster wheel).
