Topic: Irrigation system (Read 153 times) previous topic - next topic
TakeruSan
Hi there,
I have question regarding my irrigation project. As in diagram, I need to use to control 5 solenoid valves. Just say, I need to fill up water only into Tank2, which I need to open valve2, valve4, while the other valves are closed. My question is,when the water are passing through the pipe in which solenoid valve1 is connected, the water will accumulate in that pipe. Are there any way to prevent that?
Thank you so much.
Paul_KD7HB
Hi there,
Thank you so much.
What is the purpose of the extra valves? And what is the problem with water accumulating in the pipe. Is the pipe so large and long that it actually matters?
Paul
