Topic: Reading three inverted 12v PWM values (Read 1 time) previous topic - next topic
Grumpy_Mike
Thanks.
I wonder if their is some form of constant current going on with that controller, and when you remove the LEDs that messes things up. Have you tried still leaving in the LEDs on the controller and wiring your potential divider to the LED's cathodes?
Hilleskog
Thanks.
No I have not (if I understand what you mean correctly). But would that work? The LED would not be able to light up then?
Grumpy_Mike
#17
May 14, 2018, 02:33 pm Last Edit: May 14, 2018, 02:34 pm by Grumpy_Mike
Quote
Who knows? We are dealing with an unknown box of electronics so depending what is inside it the answer is yes or no.
Quote
Again it depends what is in the box.
Hilleskog
Haha true! I will try this when I have the time!
