Topic: Control 5 servos at the same time (external power supply) :0 (Read 295 times) previous topic - next topic
David_Pires
Hi I´m Dave I have 5 servos that I want to control I know that I will need an external power supply, but my problem is I want to control them at the same time.
I will have a potentiometer for each one of them and if I am rotating the potentiometer 1 and 2, motors 1 and 2 will both move. I don't know how is it possible hope u guys can help me.
vinceherman
5 servos and 5 pots.
Start out with 1 servo and 1 pot, as is done in this knob tutorial.
Then add a second pot and second servo.  It is easy to name the second instances with a 2 at the end of the name.  But you will quickly see that using arrays will be the right way to go.
Give it a try.  See how far you get.  Ask here if you have any questions.
David_Pires
Ty for all I know how to do it for one or two the problem is move the servo one at the same time of the servo two.
vinceherman
This is how I would do it.
5 servo, 5 pot algorithm
declare and assign array of 5 servo pins
declare and assign array of 5 pot pins
declare array of 5 servos
in setup
loop through 5
  attach each servos
  set each pot pins as inputs
in loop
loop through 5
  read a pot
  servo.write the mapped pot value
But seriously, start out with the knob tutorial.
slipstick
Just try it. It will do what you need. Take the delay() out.
It's not actually possible to do two things at EXACTLY the same time. The microprocessor only does one instruction followed by the next. But it's fast so it can do several things within a few microseconds of one another and unless you have a really unusual requirement that will be all you need.
Steve
