Topic: WTH is Wrong With Forum Editor??? (Read 1 time) previous topic - next topic
RayLivingston
May 05, 2018, 02:15 am Last Edit: May 05, 2018, 02:16 am by RayLivingston
The last 3 times I've made posts, they get positively littered with "color" tags placed all over in the message!  It takes more time to remove these than to create the original post!  WTH is going on?  This never once happened until just a few days ago.
Regards,
Ray L.
MAS3
Can't say i've seen that or something similar happen ever.
Did you try with different devices and /or different browsers ?
Might be on your side.
I'm using Firefox and Windows.
Have a look at "blink without delay".
Did you connect the grounds ?
Je kunt hier ook in het Nederlands terecht: http://arduino.cc/forum/index.php/board,77.0.html
RayLivingston
I'm using Chrome, which is what I've used here for over 5 years with zero problems.  This has only started happening in the last couple of weeks.
Regards,
Ray L.
Robin2
Never had that problem with Firefox 56.0
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
sterretje
No issues here. Up-to-date firefox on either windows 8 or windows 7 or chrome on my android phone.
If you understand an example, use it.
If you don't understand an example, don't use it.
Electronics engineer by trade, software engineer by profession. Trying to get back into electronics after 15 years absence.
ballscrewbob
No issues here either.
It may be an issue with your device / computer !
It may not be the answer you were looking for but its the one I am giving based on either experience, educated guess, google or the fact that you gave nothing to go with in the first place so I used my wonky crystal ball.
Coding Badly
Ditto.  Have not had any trouble.
Quote
Add-in updated?
Johan_Ha
Treat the problem as a problem with your Arduino project. Try another browser. Try another computer. Try another forum similar to arduino.cc.
____________________
If you ask for help and write 'u' instead of 'you' because you think it's convenient, I will write 'no' instead of 'yes'. For same reasons.
ballscrewbob
Given that nobody else can see or has reported the problem it is probably fair to assume that it is specific to your computer.
Maybe time to do some deep cleaning and a full security audit !
tigger
The last Win 10 feature update (1803) has done a good job of messing up keyboard layouts (may not be relevant to this post). If your chosen keyboard layout is anything other than English(United States), it will randomly and frequently changes back to English (United States). The first symptom is usually when the @ symbol becomes ". The usual temporary fix is Windows key + SHIFT to change keyboards. But, it doesn't work in the forum text boxes. A single apostrophe becomes a hash so I'm appears as I#m. The only fix I've found is to come out of the forum text, go to a text editor, type the apostrophe, go back to the forum text box and all is well, for about 30-minutes.
Plays havoc with passwords to banks etc that have non-numerical or non-alphabetical characters when you get locked out after three goes.
