Topic: 8 b TXS0108E level translator - OK with sensors? (Read 342 times) previous topic - next topic
falexandru
I am using 2 sensors on I2C
a) BMP 280 - pressure
b) TSL2561 - lingh intensity
Both are designed for 3.3 V
I wonder whether I can use the 8b TXS0108E level translator with these sensors and an Arduino Nano.
https://www.optimusdigital.ro/ro/interfata-convertoare-de-niveluri/1380-convertor-de-niveluri-logice-bidirecional-pe-8-bii-txs0108e.html?search_query=convertor&results=123
I read the DS and it is stated "automotive industry" as a typical use  (!).
Apparently, the simpler alternative - the 2 channels one that I have, cant work with two sensors on I2C,
Thank you very much!
pylon
I never used that level converter but judging from the datasheet I would say that it should work in the given environment. I assume you use the chips directly (BMP280 and TSL2561) and not some breakout board (which often include the level converters).
Quote
That probably means that it isn't a bi-directional type.
