Topic: Makershield colors for header pins (Read 456 times) previous topic - next topic
sydcomebak
May 06, 2018, 08:40 pm Last Edit: May 06, 2018, 08:56 pm by sydcomebak
First... Where is the best selection (colors) of header pins for a makershed?
Second... I have quite a few header pins already: black, white, teal, green, blue, yellow, red.
I'm building a prototyping shield for someone whose vision is worse than they will admit and I'd like to color code the major areas so that they don't have to get out magnification to figure out which place is which.
They have a history with circuit design, so I want to use colors that he might be familiar with.
Green=Ground
Etc...
In an ideal world, what colors would you use for this project?
Don't worry about having only 1 pin of a certain type or anything.  This person is pretty special to me and I'm willing to do the work to get it done right.
Thanks in advance!
-Dave
pert
Whether or not they're color blind is likely to be relevant.
sydcomebak
#2
May 06, 2018, 08:47 pm Last Edit: May 06, 2018, 08:50 pm by sydcomebak
My mistake, and excellent point!  They are not color blind.
The makershed prototype shield has:
Aref
Ground
Digital 0-13
5v
3v3
Analog 0-5
R3T
Vin
IIRC.
Grumpy_Mike
A good system is to use the resistor colour code, black zero, brown one red two and so on.
sydcomebak
#4
May 06, 2018, 11:24 pm Last Edit: May 06, 2018, 11:40 pm by sydcomebak
Grumpy_Mike, I don't think there are enough colors available out there, and this doesn't help with things like Ground or 5v vs D5 or A5.  D10-12 get tricky too... I like the idea, though!  Thanks!
Grumpy_Mike
Quote
If you get wire that telecom engineered use they are two colour wires. I think there are over a hundred combinations.
sydcomebak
I'm not sure how to combine colors.
Grumpy_Mike
#7
May 06, 2018, 11:48 pm Last Edit: May 06, 2018, 11:50 pm by Grumpy_Mike
No you do not do that you buy wires that are like that.
https://m.youtube.com/watch?v=1QXBdo-kXo8
sydcomebak
I'm not using wires.  These are header pins for a maker shield prototyping board.
pert
I think sydcomebak is talking about the colored headers like this:
sydcomebak
Pert is correct.  I cannot post images, apparently.
pert
The forum doesn't allow you to attach images that contain Exif data, I guess because they might contain GPS coordinates.
Grumpy_Mike
Quote
No you can get GPS coordinates from images posted here.
As to the problem then it seems to me the only answer is paint.
sydcomebak
Ok, I'm going to come back to this when I can post a photo of what I have and maybe then someone can help.
