Topic: Arduino Uno ,16x2 LCD without I2C ,ESP8266-01 Problem (Read 1 time) previous topic - next topic
denizkaja
Hi guys , i have a big problem ,i am working on a project getting data from wunderground ,and displayin on  a LCD screen,then operating neopixel rbg led link.So according tthe data on the screen my adafruit ring will change its color.
My problem :I can get data from wunderground and see on the serial monitor while operating esp8266.
But when i upload arduino code ,ESP8266 does not work and give no response.I can not see any data on the serial monitor else LCD :(
ESP-Code:
#include <ESP8266WiFi.h> //ESP8266 Library
#include <ESP8266HTTPClient.h> //ESP8266 Library
#include <ArduinoJson.h> //For phrasing JSON file download from https://github.com/bblanchon/ArduinoJson
const char* ssid = "****"; //Enter your Wi-Fi SSID
const char* password = "**********"; //Enter you Wi-Fi Password
String payload; //To store the JSON object as string
void setup () {
  Serial.begin(9600); //initialise serial monitor to send data to Arduino
  WiFi.begin(ssid, password); //connect to the network specified above
  while (WiFi.status() != WL_CONNECTED) { //Wait till Wi-Fi is connected
    Serial.print("Connecting.."); //Print Connecting.. till connection is established
  if (WiFi.status() == WL_CONNECTED) { //If Wi-Fi connected successfully
    HTTPClient http;  //start a HTTPClinet as http
    //####DO NOT USE THE SAME API as below
    http.begin("http://api.wunderground.com/api/b0d5d26a4589cad4/conditions/q/IN/Chennai.json");  //Enter your API
    int httpCode = http.GET(); //pass a ge                                                        t request
    if (httpCode > 0) { //Check the returning code
   //   payload = http.getString();   // Store the value on varibale Payload for debugging
   // Serial.println(payload);   //Print the payload for debugging otherwise comment both lines
/*Phrasing Data using the JSON librarey */ //Use https://arduinojson.org/assistant/ to get the phrasing values for your JSON string
const size_t bufferSize = JSON_OBJECT_SIZE(0) + JSON_OBJECT_SIZE(1) + JSON_OBJECT_SIZE(2) + 2*JSON_OBJECT_SIZE(3) + JSON_OBJECT_SIZE(8) + JSON_OBJECT_SIZE(12) + JSON_OBJECT_SIZE(56) + 2180;
DynamicJsonBuffer jsonBuffer(bufferSize);
JsonObject& root = jsonBuffer.parseObject(http.getString());
/*End of Phrasing Data*/
//Address the value sin to desired variables
JsonObject& current_observation = root["current_observation"]; //under current_observation
JsonObject& current_observation_observation_location = current_observation["observation_location"]; //under observation_location
const char* current_observation_station_id = current_observation["station_id"]; // "ICHENNAI1" //get the location detials
const char* current_observation_local_time_rfc822 = current_observation["local_time_rfc822"]; //Local time //get the local time
const char* current_observation_temperature_string = current_observation["temperature_string"]; // "90.7 F (32.6 C)" //get the temperature value
const char* current_observation_relative_humidity = current_observation["relative_humidity"]; // "73%" //get the humidity value
//Print the variables thorugh serial monitor
Serial.print (current_observation_station_id); //send the location details to Arduino
delay(100); //stability delay
Serial.print (current_observation_local_time_rfc822); //send the local time details to Arduino
Serial.print (current_observation_temperature_string); //send the temperature details to Arduino
Serial.print (current_observation_relative_humidity); //send the humidity details to Arduino
    http.end();   //Close http connection
  delay(10000);    //send values to Arduino every 30 sec.
ARDUINO UNO Code:
#include <SoftwareSerial.h>
#include <LiquidCrystal.h> //Header file for LCD from https://www.arduino.cc/en/Reference/LiquidCrystal
//const int rs = 8, en = 9, d4 = 10, d5 = 11, d6 = 12, d7 = 13; //Pins to which LCD is connected
//LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
String local_time;
String local_date;
String temperature;
String Humidity;
String payload;
SoftwareSerial ESP_Serial(1,0); //Tx,Rx
  lcd.begin(16, 2); //We are using a 16*2 LCD display
  lcd.print(" Arduino & ESP"); //Display a intro message
  ESP_Serial.begin(9600);
  delay(2000);
  lcd.clear();
  while (ESP_Serial.available() > 0)
    payload = ESP_Serial.readString();
    local_date = payload.substring(14, 20);
    local_time = payload.substring(26, 31);
    temperature = payload.substring(48, 54);
    Humidity = payload.substring(55, 60);
    delay(10);
    Serial.println(local_time);
    Serial.println(local_date);
    Serial.println(temperature);
    Serial.println(Humidity);
    lcd.clear();
    lcd.setCursor(1, 0);
    lcd.print(local_date);
    lcd.setCursor(8, 0);
    lcd.print(local_time);
    lcd.setCursor(1, 1);
    lcd.print(temperature);
    lcd.setCursor(10, 1);
    lcd.print(Humidity);
PaulS
Quote
What's that? You can't see that THIS part of the forum is about THE Arduino project, not YOUR Arduino project?
Can you understand that you and your friend can't both wear your shoes at the same time? Does it seem reasonable that you can do hardware serial AND software serial on the same pins at the same time? It does NOT to me.
