Topic: Analog input stability (Read 1 time) previous topic - next topic
vincentiu
May 10, 2018, 05:48 pm Last Edit: May 11, 2018, 10:34 am by vincentiu
Hello! I don't know if it's a topic about this open already.
I was wondering how can i get rid of this variation of the analog input as you can see in the serial print bellow for this simple code for instance. Is it something physical (small variations of the V) or software, maybe something to do with the Voltage in my opinion..
Anyway what are your sugestions?
Code: [Select]
  ReadAnalogVoltage
  Reads an analog input on pin 0, converts it to voltage, and prints the result to the Serial Monitor.
  Graphical representation is available using Serial Plotter (Tools > Serial Plotter menu).
  Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/ReadAnalogVoltage
// the setup routine runs once when you press reset:
  // initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
  // read the input on analog pin 0:
  int sensorValue = analogRead(A0);
  // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
  float voltage = sensorValue * (5.0 / 1023.0);
  // print out the value you read:
  Serial.println(voltage);
Serial print:
Code: [Select]
983
983
983
984
983
983
984
983
983
jremington
I suggest to read the "How to use this forum" post and follow the directions.
Describe your project and explain the problem, giving examples.
Post a wiring diagram (not Fritzing).
Post the code, using code tags.
wvmarle
That list of 983 and the occasional 984 is not stable enough for you? Why?
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
vincentiu
I need to output some wavetable through a external dac and the frequency varies because of this
wvmarle
Then start averaging your results. Do a rolling average of the last 10-20 readings or so, but be aware that your reaction time goes down accordingly.
Wawa
#5
May 11, 2018, 01:12 pm Last Edit: May 11, 2018, 01:18 pm by Wawa
When averaging, you still have variations, only moved by a decimal place and/or slower.
What resolution do you need.
If you need less than 10-bit, you could add hysteresis.
Try this (untested) 8-bit output sketch.
Leo..
Code: [Select]
// converts the position of a 10k lin(B) pot to a byte (0-255)
// pot connected to A0, 5volt and ground
int rawValue; // raw reading
int oldValue; // for deadband
byte Byte; // final byte
byte oldByte; // for printing
  // rawValue = analogRead(A0); // dummy read, if needed
  rawValue = analogRead(A0); // read pot
  if (rawValue < (oldValue - 2) || rawValue > (oldValue + 2)) { // add some deadband
    oldValue = rawValue; // update value
    Byte = oldValue >> 2; // convert 10-bit to 8-bit
    if (oldByte != Byte) { // only print if value changes
      Serial.print("Byte is: ");
      Serial.println(Byte);
      oldByte = Byte; // update value
Edit:
I also wrote a 0-100% (101 values) version.
vincentiu
#6
May 17, 2018, 11:16 am Last Edit: May 17, 2018, 02:41 pm by vincentiu
I need this for 12 bit res, for the digital encoder the readings are stable, but when analog in is on ±1,2 variations appearing
This is the part:
Code: [Select]
#include <Encoder.h>
Encoder enc2(3, 4);
void setup(){
void loop(){
float frqA;
const int threshold = 200; //
int analogValue = analogRead(A0);
if (analogValue > threshold) {
  frqA = map(analogRead(A0), 0, 4095, 0, 4092);
  int val1 = enc2.read(); //freqA of Wavetable **0 -> 2^32
  if(val1 <= 0) { // constrain for below 0
  enc2.write(0); // constrain the encoder object
     else if(val1 >= 1000){
     enc2.write(1000);
     frqA = constrain(val1,0.1,1000.00)*4.092; // (=1x..hz..)
  Serial.print(" freqA:");
  Serial.print(frqA);
What do you think?
wvmarle
What do you think?
I think two things after reading that message:
1) for 12-bit you need an external ADC as the Arduino's ADC offers only 10 bits resolution (the ATmega processor based ones, that is - some more exotic flavours of Arduino may offer 12-bit or higher resolution).
2) that code's indentation is such a mess I can't read it easily. Please fix that first, it's a simple button press (ctrl-T).
Wawa
4093 stable values from a common analogue pot?
Sounds like a challenge.
Leo..
vincentiu
1. It's tennsy 3.2 so it has this resolution
2. now it's better?
Leo..
it can be higher then this, you recommend even numbers, right?
wvmarle
Why didn't you tell it's a Teensy before?
Quote
2. now it's better?
I think you forgot to post your updated code.
Quote
We normally recommend powers of 2 as that's how computers work, so 4092.
But 4092 distinct values from a regular pot? Not much chance to get that perfectly stable. Vibrations from you touching the table may be enough to jump a few points up and down. The higher the resolution of your ADC, the more noise you will see.
Whandall
How is this 4092 more connected to powers of two than 4093?
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. (D.Adams)
wvmarle
Because computers are better at numbers than I am.
Make that 4096 then.
Wawa
But :smiley-eek: OP asked for this
Leo..
wvmarle
That is just too weird a request so it must have popped right out of the realm of possibilities of "what an OP could actually want" making me completely miss the whole request.
