Topic: Problem with.... something? Working with assembly... (Read 586 times) previous topic - next topic
losmi
Hello!
I'm stuck at this problem. I have .ino and .S files, whole point is in working with TM1637 7-seg display without using library, to save space which is scarce in ATtiny13, which is my platform in this sketch.
You can ignore SETUP part, and LOOP is writting "1111" and "2222" to display alternately. Now, function which writes "2222" is identical to the routine which writes "1111", but 1111 is written well and 2222 is not. Difference is in that in "2222" registers r16, r17, r18 and r19 - one register for each digit - are used to pass value to r24 (r24 holds argument for function "TM1637_write_byte_parameter_r24_uses_r25_returns_r24").
Code is organised in the way that INO file mostly just calls functions defined in S file.
INO file:
Code: [Select]
// C:\Users\ADAS\AppData\Local\Temp\arduino_build_112814>objdump -S tm1637cpp.ino.elf > tm1637cpp.txt
// TM 1637 7-seg display test code, no library
#define TM1637_DIO_PIN PB0
#define TM1637_CLK_PIN PB1
extern "C" {
 // function prototypes
 void TM1637_DELAY_US();
 void TM1637_start();
 void TM1637_stop();
 void TM1637_write_segments_arguments_r16_r17_r18_r19_uses_r24();
 void TM1637_write_byte_parameter_r24_uses_r25_returns_r24();
asm("in r24, 0x17");
    asm("ori r24, 0x03");
asm("out 0x17, r24");
// initialise display and set brightness
// 0x88 is dim and increasing value to 0x8C increases brightness
TM1637_start();
asm("ldi r24, 0x8c");
TM1637_stop();
// clear display
  TM1637_start();
asm("ldi r24, 0x40");
TM1637_stop();
TM1637_start();
asm("ldi r24, 0xc0");
asm("ldi r24, 0xff");
TM1637_stop();
// this routine is working good, it writes "1111" on display:
TM1637_start();
TM1637_stop();
TM1637_start();
asm("ldi r24, 0x06");
TM1637_stop();
delay(800);
// this routine is identic to previous, but does not work well
// (something about using those registers?), it tries to write "2222":
asm("ldi r16, 0x5b");
asm("ldi r17, 0x5b");
asm("ldi r18, 0x5b");
asm("ldi r19, 0x5b");
delay(800);
S file:
Code: [Select]
#define DIO_PIN 0 ; PB0
#define CLK_PIN 1 ; PB1
#define DDRB 0x17
#define PORTB 0x18
.global TM1637_DELAY_US
.global TM1637_start
.global TM1637_stop
.global TM1637_write_segments_arguments_r16_r17_r18_r19_uses_r24
.global TM1637_write_byte_parameter_r24_uses_r25_returns_r24
TM1637_DELAY_US: ; 50 us at 1.2 mhz
 ; rcall takes 3 cycles
 ; ret takes 4 cycles
 ; we need another 53 cycles
    ldi  r18, 25 ; 1 cycle
L1: dec  r18
    breq L1 ; 1 cycle for true and 2 for false
 ret
TM1637_start:
sbi PORTB, DIO_PIN
sbi PORTB, CLK_PIN
rcall TM1637_DELAY_US
cbi PORTB, DIO_PIN
ret
TM1637_stop:
cbi PORTB, CLK_PIN
cbi PORTB, DIO_PIN
sbi PORTB, CLK_PIN
sbi PORTB, DIO_PIN
ret
; This function does the same thing as the routine in THE LOOP
; but this one doesn't work well:
TM1637_write_segments_arguments_r16_r17_r18_r19_uses_r24:
rcall TM1637_start
ldi r24, 0x40
rcall TM1637_write_byte_parameter_r24_uses_r25_returns_r24
rcall TM1637_stop
rcall TM1637_start
ldi r24, 0xc0
mov r24, r16
mov r24, r17
mov r24, r18
mov r24, r19
rcall TM1637_stop
ret
TM1637_write_byte_parameter_r24_uses_r25_returns_r24:
ldi    r25, 0x08 ; r25 will serve as counter in for loop (i)
forloop:
cbi    0x18, 1 ; CLK_PIN - LOW
sbrs   r24, 0 ; skip if first bit is 1
rjmp   r24_first_bit_aint_1
sbi    0x18, 0 ; DIO - HIGH
rjmp   r24_first_bit_is_1
r24_first_bit_aint_1:
cbi    0x18, 0 ; DIO_PIN - LOW
r24_first_bit_is_1:
sbi    0x18, 1 ; CLK_PIN - HIGH
lsr    r24 ; r24 shift right by one place
subi   r25, 0x01 ; i--
brne   forloop ; jump if i isn't null
cbi    0x18, 1 ; CLK - LOW
cbi    0x17, 0 ; DIO - INPUT
sbi    0x18, 0 ; DIO - ENABLE PULL-UP
sbic   0x16, 0 ; skip if DIO_PIN (set as input) reads false
rjmp   ack_is_true ; if (ack), jump downthere
ldi    r24, 0x00 ; return ACK (not used, should remove this line)
continue_execution:
sbi    0x17, 0 ; DIO_PIN - OUTPUT
ret
ack_is_true:
sbi    0x17, 0 ; set DIO_PIN as output
ldi    r24, 0x01 ; return ACK (not used, should remove this line)
rjmp   continue_execution
losmi
ard_newbie
IMO you scratch r18 in TM1637_DELAY_US whereas you are using this register in TM1637_write_segments_arguments_r16_r17_r18_r19_uses_r24.  Use r0 instead in TM1637_DELAY_US should fix the issue.
losmi
Dude you're my saviour!!! I usually code after my family goes to sleep so I'm not very concentrated and these stupid details slip through... Anyways, I'm putting registers used in names of functions, and now my DELAY function uses r20 instead of 18 and is now called "TM1637_DELAY_US_uses_r20"
THANX MAN!!!
ard_newbie
A better practice would be to pass arguments inside your functions:
The first one will be received in 24/r25, second in r22/r23, third in r20/r21, and fourth in r18/r19.
losmi
Sorry but I don't get it?
ard_newbie
#6
May 12, 2018, 08:35 pm Last Edit: May 12, 2018, 08:50 pm by ard_newbie
Here is a very basic example sketch to blink an LED by calling a function with two arguments:
The .ino sketch:
Code: [Select]
extern "C" {
  void start(uint8_t arg1, uint16_t arg2); // First argument is passed thru r24/r25, second thru r22/r23,...
int main(void) {
  start(250, 3000);
while(true);
The .S part of the sketch:
Code: [Select]
; Blink LED on PB5(Arduino Uno pin 13)
#define __SFR_OFFSET 0
#include   "avr/io.h"
.global start
start:
SBI      DDRB, 5
blink:
mov r20, r24 ;***
CALL       delay_n_ms
SBI      PORTB, 5
mov r20, r24 ;***
CALL       delay_n_ms
CBI      PORTB, 5
JMP       blink
delay_n_ms:
; Delay about r20 * 1ms.  Destroys r20, r30, and r31.
; One millisecond is about 16000 cycles at 16MHz.
; The basic loop takes about 5 cycles, so we need about 3000 loops.
mov r31, r23 ;***
mov r30, r22 ;***
delaylp:
sbiw r30, 1
brne delaylp
subi r20, 1
brne delay_n_ms
ret
losmi
Okay I get it - to let compiler worry about which register is used, but then I don't save space because compiler inserts bunch of PUSH-es in the beginning of function and POP's at the end of functions. That eats space, and I don't need 2 registers for one argument because I hope to chop down all of my variables to 8 bits, kill all 16 bit integers.
Thank you again for your help!
westfw
Quote
he's advocating the opposite of what I recommended a while ago.  Using a standard argument calling convention is definitely "better practice."  Using customer argument calling conventions can save you space.  As you're finding out, it also can cause difficult-to-find bugs.
losmi
Yes, I'm a victim of my optimisation for size, I hope in my next project I won't have to do any considerable optimizations :)
