Topic: Error compiling (Read 2367 times) previous topic - next topic
daba
I have a uint8_t array in PROGMEM I am trying to read from (byte 8), second line of the code below.
Compiler error is "expected ')' before ';' token".
If I remark out this line, the sketch compiles no problem....
I can't see anything wrong, almost copied from the reference text....
if (! data_valid) {
   colour = pgm_read_byte_near( RemoteXY_CONF[8] );
   get_LED_RGB(colour);
   RemoteXY.valid_r = red;
   RemoteXY.valid_g = grn;
   RemoteXY.valid_b = blu;
Perhaps it just needs a fresh pair of eyes......
Everything works with smoke. If you let it out, things stop working.
TolpuddleSartre
Perhaps we need code tags and all your code, and the exact error message.
daba
I can't post ALL the code, it exceeds the maximum number of characters
"colour" is a global uint8_t, so are red, grn, and blue
the get_LED_RGB function works if I just put a number as the argument to it
It's throwing up a lot of references to the declaration of the RemoteXY_CONF array, which is in RemoteXY.h
Here's all the error messages....
Arduino: 1.8.5 (Windows 7), Board: "Arduino Nano, ATmega328P"
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28:0,
                 from sketch\BaitBoat2.ino.cpp:1:
C:\Users\Dave\Documents\Arduino\BaitBoat2\BaitBoat2.ino: In function 'void loop()':
C:\Users\Dave\Documents\Arduino\libraries\RemoteXY/RemoteXY.h:158:23: error: expected primary-expression before 'const'
 #define RemoteXY_CONF const PROGMEM RemoteXY_CONF_PROGMEM
C:\Users\Dave\Documents\Arduino\BaitBoat2\BaitBoat2.ino:557:35: note: in expansion of macro 'RemoteXY_CONF'
       colour = pgm_read_byte_near(RemoteXY_CONF[8]);
C:\Users\Dave\Documents\Arduino\libraries\RemoteXY/RemoteXY.h:158:23: error: expected ')' before 'const'
BaitBoat2:557: error: expected ')' before ';' token
exit status 1
option enabled in File -> Preferences.
TolpuddleSartre
See how much easier it is, when you can see the whole picture?
Do the macro expansion manually, and you'll see the problem.
daba
I have no idea what you mean by "Do the macro expansion manually".
Perhaps if you posted the whole of the details it might get easier, but one-liners are not much help to a novice.
Are you suggesting I have to modify RemoteXY.h ??
Danois90
The macro "RemoteXY_CONF" is invalid, fix it :)
Instead of mocking what's wrong, teach what's right! ;)
When you get help, remember to thank the helper and give some karma!
Please, do NOT send me any private messages!!
daba
Here is the code section that defines the bytes in RemoteXY_CONF
It is in my sketch, not in RemoteXY.h
Code: [Select]
//        RemoteXY include library          //
// RemoteXY select connection mode and include library
#define REMOTEXY_MODE__HARDSERIAL
#include <RemoteXY.h>
// RemoteXY connection settings
#define REMOTEXY_SERIAL Serial
#define REMOTEXY_SERIAL_SPEED 115200
// RemoteXY configurate
#pragma pack(push, 1)
uint8_t RemoteXY_CONF[] =
  { 255,35,0,10,0,13,3,8,178,4,
  131,1,0,57,13,5,1,8,31,77,
  97,105,110,0,129,0,4,1,40,5,
  0,8,66,97,105,116,66,111,97,116,
  32,67,111,110,116,114,111,108,0,131,
  0,36,57,13,5,2,16,8,83,101,
  116,117,112,0,5,32,3,12,42,42,
  1,178,26,31,129,0,45,32,3,4,
  1,8,82,0,129,0,0,31,2,4,
  1,8,76,0,129,0,20,8,9,4,
  1,8,70,87,68,0,4,0,52,10,
  8,47,1,204,26,129,0,52,58,9,
  3,1,24,76,105,103,104,116,115,0,
  129,0,51,5,10,3,1,24,66,97,
  116,116,101,114,121,0,130,0,60,1,
  4,4,1,134,130,0,48,1,12,4,
  1,1,66,131,48,1,16,4,1,30,
  8,65,22,69,0,10,10,1,1,0,
  70,1,8,8,1,246,31,80,0,129,
  0,81,4,7,3,1,24,72,111,111,
  107,0,129,0,79,7,11,3,1,24,
  82,101,108,101,97,115,101,0,65,22,
  90,0,10,10,1,1,0,91,1,8,
  8,1,246,31,83,0,66,1,93,14,
  4,39,1,1,17,4,0,91,10,8,
  47,1,2,26,66,1,72,14,4,39,
  1,1,17,4,0,70,10,8,47,1,
  2,26,129,0,79,58,12,3,1,24,
  72,111,112,112,101,114,115,0,129,0,
  20,55,8,4,1,8,82,69,86,0,
  129,0,46,1,14,5,2,24,83,101,
  116,117,112,0,129,0,2,14,30,3,
  2,8,80,111,114,116,32,72,111,112,
  112,101,114,32,83,101,114,118,111,32,
  37,0,129,0,35,8,12,3,2,8,
  77,105,110,0,7,22,35,12,11,5,
  2,94,26,2,129,0,53,8,6,3,
  2,8,77,97,120,0,7,22,52,12,
  11,5,2,94,26,2,129,0,1,21,
  30,3,2,8,83,116,98,100,32,72,
  111,112,112,101,114,32,83,101,114,118,
  111,32,37,0,7,22,35,19,11,5,
  2,94,26,2,7,22,52,19,11,5,
  2,94,26,2,129,0,9,28,31,3,
  2,8,82,117,100,100,101,114,32,83,
  101,114,118,111,32,37,32,32,32,40,
  45,47,43,41,0,7,22,44,26,11,
  5,2,94,26,2,129,0,11,35,30,
  3,2,8,84,104,114,111,116,116,108,
  101,32,69,83,67,32,37,32,32,32,
  40,45,47,43,41,0,7,22,44,33,
  11,5,2,94,26,2,129,0,16,50,
  15,3,2,8,66,97,116,116,101,114,
  121,32,40,86,41,0,7,14,35,48,
  11,5,2,94,26,2,2,129,0,1,
  43,30,3,2,8,72,111,111,107,32,
  82,101,108,101,97,115,101,32,84,105,
  109,101,32,83,0,7,22,35,41,11,
  5,2,94,26,2,1,2,80,0,20,
  6,2,204,31,82,101,115,101,116,32,
  73,110,100,105,99,97,116,111,114,115,
  0,129,0,84,8,13,3,2,8,68,
  105,114,101,99,116,105,111,110,0,129,
  0,68,22,6,3,2,8,84,114,105,
  109,0,7,22,66,26,11,5,2,94,
  26,2,7,22,66,33,11,5,2,94,
  26,2,65,31,79,51,21,12,2,129,
  0,82,52,14,3,2,178,0,1,2,
  80,54,19,6,2,0,1,83,97,118,
  101,0,129,0,48,13,2,4,2,8,
  60,0,129,0,48,20,2,4,2,8,
  60,0,2,0,81,12,18,5,2,29,
  24,1,136,82,69,86,0,78,79,82,
  0,2,0,81,19,18,5,2,29,24,
  1,136,82,69,86,0,78,79,82,0,
  2,0,81,26,18,5,2,29,24,1,
  136,82,69,86,0,78,79,82,0,2,
  0,81,33,18,5,2,29,24,1,136,
  82,69,86,0,78,79,82,0 };
// this structure defines all the variables of your control interface
struct {
    // input variable
  int8_t joystick_1_x; // =-100..100 x-coordinate joystick position
  int8_t joystick_1_y; // =-100..100 y-coordinate joystick position
  int8_t lights; // =0..100 slider position
  uint8_t hkr_p; // =1 if button pressed, else =0
  uint8_t hkr_s; // =1 if button pressed, else =0
  int8_t stbdhopper; // =0..100 slider position
  int8_t porthopper; // =0..100 slider position
  int16_t PHop_Min;  // −32767.. +32767
  int16_t PHop_Max;  // −32767.. +32767
  int16_t SHop_Min;  // −32767.. +32767
  int16_t SHop_Max;  // −32767.. +32767
  int16_t Rud_Rng;  // −32767.. +32767
  int16_t Thr_Rng;  // −32767.. +32767
  float Batt_Volts;
  int16_t Hook_Rel;  // −32767.. +32767
  uint8_t Reset; // =1 if button pressed, else =0
  int16_t Rud_Trim;  // −32767.. +32767
  int16_t Thr_Trim;  // −32767.. +32767
  uint8_t Save_Settings; // =1 if button pressed, else =0
  uint8_t PHop_Rev; // =1 if switch ON and =0 if OFF
  uint8_t SHop_Rev; // =1 if switch ON and =0 if OFF
  uint8_t Rud_Rev; // =1 if switch ON and =0 if OFF
  uint8_t Thr_Rev; // =1 if switch ON and =0 if OFF
    // output variable
  int8_t batt_meter; // =0..100 level position
  uint8_t rel_flag_p_r; // =0..255 LED Red brightness
  uint8_t rel_flag_p_g; // =0..255 LED Green brightness
  uint8_t rel_flag_s_r; // =0..255 LED Red brightness
  uint8_t rel_flag_s_g; // =0..255 LED Green brightness
  int8_t s_max; // =0..100 level position
  int8_t p_max; // =0..100 level position
  uint8_t valid_r; // =0..255 LED Red brightness
  uint8_t valid_g; // =0..255 LED Green brightness
  uint8_t valid_b; // =0..255 LED Blue brightness
    // other variable
  uint8_t connect_flag;  // =1 if wire connected, else =0
} RemoteXY;
#pragma pack(pop)
//           END RemoteXY include          //
daba
How can it be "wrong" if works...
This array block is pushed to the connected mobile to define the control screens.
So what exactly is stopping me reading from that array ?
Jobi-Wan
Just to clarify what TolpuddleSartre wrote...
When you #define something, that's a macro.
#define bla blub
From that point on, the compiler will replace any occurrence of bla with blub. That's called macro expansion. It expands the thing you've #defined to the stuff you've #defined it to be. In this case, it expands bla into blub.
In your case, RemoteXY_CONF is a macro. It occurs in the line you're asking about. That line looks normal if you don't know that RemoteXY_CONF is a macro, but do the macro expansion manually, and you'll see the problem.
Danois90
You are using the macro "#define RemoteXY_CONF const PROGMEM RemoteXY_CONF_PROGMEM" as argument to "pgm_read_byte_near", your code will expand to:
Code: [Select]
pgm_read_byte_near(const PROGMEM RemoteXY_CONF_PROGMEM[8]);
Which is a malformed statement, therefore the macro is not working.
daba
#define bla blub
From what I can see RemoteXY_CONF is a uint8_t array, I can't see it #define'd anywhere, it must be in the RemoteXY library....
Does this mean that there is no way to read bytes from RemoteXY_CONF ??
I would not have a clue how to "do the macro expansion manually" with my sketch....
Here's a simpler example with much less "CONF"
Code: [Select]
#define REMOTEXY_MODE__SOFTSERIAL
#include <SoftwareSerial.h>
#define REMOTEXY_SERIAL_RX 2
#define REMOTEXY_SERIAL_TX 3
#define REMOTEXY_SERIAL_SPEED 9600
  { 255,1,0,0,0,11,0,8,108,0,
  4,0,26,14,10,36,2,26 };
struct {
    // input variable
  int8_t slider_1; // =0..100 slider position
    // other variable
} RemoteXY;
#pragma pack(pop)
Jobi-Wan
In post #2 where you post all messages, you can see where and how it is #defined.
daba
In which case, I'll go no further, I'm not into modifying someone else's library code.... I'll send him a message with a link to this thread, and see if he can "fix it" so we can read bytes from that array.
Jobi-Wan
Does the library come with any example sketches that show how it is intended to be used?
TolpuddleSartre
How about using the time waiting for a response reading this ?
