Topic: how to get the 1Msps in Due (Read 1 time) previous topic - next topic
ED201
May 13, 2018, 02:50 pm Last Edit: May 13, 2018, 10:52 pm by surbyte
I went over bunch of examples, some were producing just garbage and the fastest I got was 666 ksps
here is code from other place, the author claims it is 1 Msps
the data sheet says 1 Msps ( http://www.microchip.com/wwwproducts/en/ATSAM3X8E )
Code: [Select]
     int t=analogRead(0);
     ADC->ADC_MR |= 0x80; // these lines set free running mode on adc 7 (pin A0)
     ADC->ADC_CR=2;
     ADC->ADC_CHER=0x80;
     int t=micros();
     int q=0;
     int a0;
     for(int i=0;i<1000000;i++){
       while((ADC->ADC_ISR & 0x80)==0); // wait for conversion
       a0=ADC->ADC_CDR[7];              // read data
       q+=a0;
     t=micros()-t;
     Serial.print("1 million conversions in ");Serial.print(t);Serial.println(" micros");
but it takes 1 500 000 microseconds for 1 000 000 samples,
Due has been around for a while and I cannot find code which gives 1 Msps
Am I missing something
thanks
Moderator: Add tags to code and link.
ard_newbie
Try this code, ADC and DAC in Free Running mode:
Code: [Select]
/*  Free Run ADC conversions of 1 analog input (A0)                */
/*  Free Run DAC output on channel 1 (DAC1)                        */
  pinMode(LED_BUILTIN, OUTPUT);
  adc_setup();
  dac_setup();
/*************  Configure adc_setup function  *******************/
void adc_setup() {
  PMC->PMC_PCER1 |= PMC_PCER1_PID37;                    // ADC power ON
  ADC->ADC_CR = ADC_CR_SWRST;                           // Reset ADC
  ADC->ADC_MR |=  ADC_MR_TRGEN_DIS                      // Hardware trigger disable
                  | ADC_MR_FREERUN
                  | ADC_MR_PRESCAL(0);                  // Or PRESCAL (1) to limit to 21 MHz !
  ADC->ADC_ACR = ADC_ACR_IBCTL(0b01);                   // For frequencies > 500 KHz
  ADC->ADC_IER = ADC_IER_EOC7;                          // End Of Conversion interrupt enable for channel 7
  NVIC_EnableIRQ(ADC_IRQn);                             // Enable ADC interrupt
  ADC->ADC_CHER = ADC_CHER_CH7;                         // Enable Channel 7 = A0
void ADC_Handler() {
  static uint32_t Count;
  DACC->DACC_CDR = ADC->ADC_CDR[7];                    // Reading ADC->ADC_CDR[i] clears EOCi bit
 // For debugging only
  if (Count++ == 1000000) {
    Count = 0;
    PIOB->PIO_ODSR ^= PIO_ODSR_P27;
void dac_setup ()
  PMC->PMC_PCER1 = PMC_PCER1_PID38;                   // DACC power ON
  DACC->DACC_CR = DACC_CR_SWRST ;                     // Reset DACC
  DACC->DACC_MR = DACC_MR_TRGEN_DIS                   // Hardware trigger disable, Free Run mode
                  | DACC_MR_USER_SEL_CHANNEL1         // select channel 1
                  | DACC_MR_REFRESH (1)
                  | DACC_MR_STARTUP_8
                  | DACC_MR_MAXS;
  DACC->DACC_CHER = DACC_CHER_CH1;                   // enable channel 1 = DAC1
ED201
#2
May 14, 2018, 02:46 am Last Edit: May 14, 2018, 02:49 am by ED201
I found a fix, it is now 1 us, 1 Msps but I cannot find a way to do this on pin A7, everybody is using pin A0
int x;                                           // read value
int myArray[20000];
  Serial.begin(9600);                                           // initialize the serial port:
  REG_ADC_MR = 0x10380180;                       // change from 10380200 to 10380180, 1 is the PREESCALER and 8 means FREERUN
  ADC -> ADC_CHER = 0x80;                        // enable ADC on pin A0
  int t = micros();                    // init time an elapsed time, in micro seconds
 for(int i = 0; i < 20000; i++) {
    // instrucction to measure
   myArray = ADC->ADC_CDR[7];         // read value A0
  int t1 = micros();
  Serial.println(t1-t);
  delay(2000);
ard_newbie
#3
May 14, 2018, 04:58 am Last Edit: May 14, 2018, 11:04 am by ard_newbie
Edit your post and post your code between code tags <\>
To sample A7 instead of A0, enable ADC channel 0 (From https://gist.github.com/pklaus/5921022):
Code: [Select]
volatile int bufn, obufn;
const uint16_t bufsize = 256;
uint16_t buf[4][bufsize];
  SerialUSB.begin(250000);
  while(!SerialUSB);
  adc_setup();
  while (obufn == bufn); // wait for buffer to be full
  SerialUSB.write((uint8_t *)buf[obufn], 512); // send it - 512 bytes = 256 uint16_t
  obufn = (obufn + 1) & 3;
/***************  Configure ADC  ******************************/
void adc_setup() {
  PMC->PMC_PCER1 |= PMC_PCER1_PID37; // Enable ADC
  ADC->ADC_MR = ADC_MR_TRGEN_DIS
                | ADC_MR_FREERUN_ON                         // free running
  ADC->ADC_CHER = ADC_CHER_CH0;           // Enable Channel 0 = A7
  ADC->ADC_IER |= ADC_IER_ENDRX ;
  /*************      PDC/DMA  buffer filling *******************/
  ADC->ADC_RPR = (uint32_t)buf[0];        // DMA buffer
  ADC->ADC_RCR = bufsize;
  ADC->ADC_RNPR = (uint32_t)buf[1];       // next DMA buffer
  ADC->ADC_RNCR = bufsize;
  bufn = obufn = 1;
  ADC->ADC_PTCR |= ADC_PTCR_RXTEN;        // Enable PDC receiver channel request
  ADC->ADC_CR = ADC_CR_START;
void ADC_Handler() {                // move DMA pointer to next buffer
  if ( ADC->ADC_ISR & ADC_ISR_ENDRX) {
    bufn = (bufn + 1) & 3;
    ADC->ADC_RNPR = (uint32_t)buf[bufn];
  if (Count++ > 3906) { // 3906 = 10E6/256
    Count = 0;
With the code below, I can reach 999 938 Hz in Free Running Mode with Prescal (1) and 1 908 976 Hz with Prescal (0), not bad for ADC conversions followed by DAC conversions of 128 Half words buffers:
Code: [Select]
/*                  ADC and DAC in FREE Running Mode and PDC DMA                           */
volatile uint32_t Timestamp, Oldmicros;
volatile boolean Flag;
volatile uint8_t bufn, bufn_dac;
const uint16_t bufsize = 128;            // size must be a power of 2
const uint8_t bufnumber = 4;             // bufnumber > 2, better be a power of 2
const uint8_t _bufnumber = bufnumber - 1;
uint16_t buf[bufnumber][bufsize];        // bufnumber buffers of bufsize samples,
  Serial.begin(250000);
  adc_setup();
  dac_setup();
  Oldmicros = micros();
  if (Flag) {
    Flag = false;
    Serial.println(Timestamp);
void adc_setup() {
  ADC->ADC_MR |=  ADC_MR_TRGEN_DIS                      // Free Running Mode selected
                  | ADC_MR_FREERUN
                  | ADC_MR_PRESCAL(0);                  // Or PRESCAL (1) to reduce ADC frequency to 21 MHz
  ADC->ADC_IER = ADC_IER_ENDRX;                         // End Of Conversion interrupt enable for channel 7
  /*********  code for PDC/DMA  buffer filling sequence **********/
  ADC->ADC_RPR = (uint32_t)buf[1];                      // DMA buffer - First one will be buf[1]
  ADC->ADC_RNPR = (uint32_t)buf[2];                     // next DMA buffer
  bufn = 2;
  ADC->ADC_PTCR |= ADC_PTCR_RXTEN;                      // Enable PDC Receiver channel request
/*********  Call back function for ADC PDC/DMA **************/
void ADC_Handler () {
  bufn = (bufn + 1) & _bufnumber;
  bufn_dac = (bufn_dac + 1) & _bufnumber;
  DACC->DACC_TNPR = (uint32_t)buf[bufn_dac];
  DACC->DACC_TNCR = bufsize;
  if (Count++ == 7812) { //1000000/128 ~7812
    Timestamp = micros() - Oldmicros;
    Flag = true;
    Count = 0;
    PIOB->PIO_ODSR ^= PIO_ODSR_P27;  // Toggle LED_BUILTIN every 1 Hz
/*************  Configure dac_setup function  *******************/
void dac_setup ()
  DACC->DACC_MR = DACC_MR_TRGEN_DIS                   // Free Running Mode selected
                  | DACC_MR_STARTUP_8
                  | DACC_MR_MAXS;
  DACC->DACC_ACR = DACC_ACR_IBCTLCH0(0b10)
                   | DACC_ACR_IBCTLCH1(0b10)
                   | DACC_ACR_IBCTLDACCORE(0b01);
  DACC->DACC_IER = DACC_IER_ENDTX;
  /*************   configure PDC/DMA  for DAC *******************/
  DACC->DACC_TPR  = (uint32_t)buf[0];                 // DMA buffer
  DACC->DACC_TCR  = bufsize;
  DACC->DACC_TNPR = (uint32_t)buf[1];                 // next DMA buffer
  bufn_dac = 1;
  DACC->DACC_PTCR = DACC_PTCR_TXTEN;                  // Enable PDC Transmit channel request
ED201
thanks for the code, it is a little long, the code  I found is short and simple and it seems to be working.
I am not sure if I understand it well but I need to make a call to ADC_Handler() withing the loop() to take one 1 us reading. it is a little complicated to understand it right away, I am not so good.
Speklap
No, ADC_Handler gets called when your conversion is complete, -if you enable the interrupt. You set the speed of the adc in its setup registers. No need to call it within the loop().
I came on the same link as ard's, not quite sure you can do shorter than that.
