Topic: Choose servos for hexapod (Read 6949 times) previous topic - next topic
carynx
I'll ride a hexapod with 6 legs and 12 servos and I have some doubts about choosing the servos.
Is it better servo with plastic or metal gears?
How many kg should be able to lift the servos to the hexapod?
I have seen these models are not very expensive and not which to choose.
TowerPro SG90 -> 1.2/1.6 kg/cm -> 0.12sec
Tower Pro MG90S -> 1.8/2.2 Kg/cm -> 0.10/0.08 sec
Tower Pro SG5010 -> 3.1/4.5 kg-cm -> 0.17/0.14 sec
Tower Pro MG995 -> 10 kg-cm -> 0.2 sec
Thanks and sorry for my English.
zoomkat
What servos to use will depend on the type of hexapod you want to build. You really need to study the hexapod kits that are available to see what servos are successfully used to build them.
Google forum search: Use Google Search box in upper right side of this page.
Why I like my 2005 Rio Yellow Honda S2000  https://www.youtube.com/watch?v=pWjMvrkUqX0
carynx
The problem with kits is that each one uses servos with different characteristics and range from 4kg to 10kg.
The logic of that support would take more kg.
Let's see if anyone has mounted a hexapod can recommend me something.
Benji
It depends on the weight you need to lift, the road the leg has to travel, and the weight it needs to support while in position.
Without drawings, estimate on the weight and so on there is little you can advise.
My only advice is don't go for the cheapest servo's you can find.
From my previous experience in RC car racing, tower pro is probably the worst servo you can get. They are slow, unreliable and prone to burn out. (I've seen more than 1 burn out completely, which is pretty freaky when racing a 60kmp/h car filled up with nitromethanol).
The servo's are the thing that will make your hexapod more than a piece of plastic/metal/wood with an MCU on it. Don't go the cheapest way, pay a bit more and enjoy your pod all the more.
keeper63
I don't have any experience in building a hexapod, but if I were to design one (or any small walking robot), I would go for servos with the max torque (kg-cm) I could afford, with metal gears, and most importantly metal bushings or full ball-bearings on both ends of the output shaft of the servos. Many cheap servos use no shaft support other than the plastic hole the shaft exits from as a bearing. Given the load placed on the servos, good shaft support is a must. Sintered bronze bushings (Oilite) would probably be ok for a small hexapod, but if full ball-bearings versions are available and only at a small amount to the cost of a single servo, spend the extra money, because it will be worth it in the long run. Finally, you only need to worry about servo speed if you are looking to have your robot scampering around like a crazed insect; you may find the speed of a servo not worth the extra money (or you might find youself spending money on something you don't end up using) - but that part is ultimately your call, as only you know what you will want the robot to do in the end, of course.
I will not respond to Arduino help PM's from random forum users; if you have such a question, start a new topic thread.
jraskell
Quote
I'll ride a hexapod
Quote
Are you talking about building a hexapod that can support the weight of a person?
carynx
No, the hexapod should only support their own weight.
I feel the error in translation, but my English is a bit poor.
