Topic: Compilation error (Read 2206 times) previous topic - next topic
VenomSnake
I'm working with a lilytiny cjmcu and i'm triying to add a dht 11. But when i try to complilate the program the arduino IDE said something like "Error compiling for digispark card (default - 16.5mhz)".
Besides of that i also want to see the values of temperature and moisture but the funcion serian doesn't work with the lilytiny...
¿What can i do?
I really would appreciate any kind of help
pert
When you encounter an error you'll see a button on the right side of the orange bar "Copy error messages". Click that button. Paste the error in a message here USING CODE TAGS (</> button on the toolbar).
VenomSnake
#2
May 17, 2018, 06:55 pm Last Edit: May 17, 2018, 06:59 pm by VenomSnake
Arduino:1.8.5 (Windows 8.1), Tarjeta:"Digispark (Default - 16.5mhz)"
In file included from C:\Program Files (x86)\Arduino\libraries\DHT-sensor-library-master\DHT_U.cpp:22:0:
C:\Program Files (x86)\Arduino\libraries\DHT-sensor-library-master\DHT_U.h:25:29: fatal error: Adafruit_Sensor.h: No such file or directory
#include <Adafruit_Sensor.h>
compilation terminated.
exit status 1
Error compilando para la tarjeta Digispark (Default - 16.5mhz).
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
uxomm
#3
May 17, 2018, 08:50 pm Last Edit: May 17, 2018, 08:52 pm by uxomm
Looks like you have not (properly) installed the sensor's library, the error message says:
You can find the missing library here:
https://github.com/adafruit/Adafruit_Sensor
Download the library by klicking "Clone or download" and "Download ZIP"
Remember the folder you did download the file.
After downloading is complete, open Arduino-IDE and go to
Menu / Sketch / Include Library / Add .ZIP Library...
navigate to the downloaded ZIP file, select it and klick OPEN.
If the language of the Arduino-IDE is set to Spanish it is accordingly:
Programa / Includir Librería / Añadir librería .ZIP...
Always decouple electronic circuitry.
freaklabs
You can also try to search for the library in the Arduino IDE's library installer. If you can locate it, it will download and install automagically.
FreakLabs
Wireless Technology for the environment, wildlife, and agriculture
https://freaklabs.org
https://hackerfarm.jp
Twitter: @freaklabs
