Topic: DHT11 code problem (Read 499 times) previous topic - next topic
sex92toso
I am, apart from being new in this Arduino world, getting struggle to see some reasonable values from this sensor. I am getting for both temperature and humidity a 0.00 value.
Here is the simple code needed for it, hope someone can understand this.
Code: [Select]
#include <dht.h>
#define dht_apin A0 // Analog Pin sensor is connected to
dht DHT;
void setup(){
  delay(500);//Delay to let system boot
  Serial.println("DHT11 Humidity & temperature Sensor\n\n");
  delay(1000);//Wait before accessing Sensor
void loop(){
    DHT.read11(dht_apin);
    Serial.print("Current humidity = ");
    Serial.print(DHT.humidity);
    Serial.print("%  ");
    Serial.print("temperature = ");
    Serial.print(DHT.temperature);
    Serial.println("C  ");
    delay(5000);
I would like to ask also if there is any difference between taking an analog Pin or digital in this case. I am here using analog as I supposed that digital will only give a 0 or a 1 while analog gives possible values between 0 and 1023
