* This code is for the project at
* http://www.iliketomakestuff.com/how-to-automate-a-dust-collection-system-arduino
* All of the components are list on the url above.
This script was created by Bob Clagett for I Like To Make Stuff
For more projects, check out iliketomakestuff.com and modified by Terry Neal
Includes Modified version of "Measuring AC Current Using ACS712"
http://henrysbench.capnfatz.com/henrys-bench/arduino-current-measurements/acs712-arduino-ac-current-tutorial/
Parts of this sketch were taken from the keypad and servo sample sketches that comes with the keypad and servo libraries.
Uses https://github.com/adafruit/Adafruit-PWM-Servo-Driver-Library
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
// called this way, it uses the default address 0x40
//Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
// you can also call it with a different address you want
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x41);
// Depending on your servo make, the pulse width min and max may vary, you
// want these to be as small/large as possible without hitting the hard stop
// for max range. You'll have to tweak them as necessary to match the servos you
// have!
//servos used DS3218mg
// our servo # counter
uint8_t servoCount = 6;
uint8_t servonum = 0;
const int OPEN_ALL = 100;
const int CLOSE_ALL = 99;
boolean buttonTriggered = 0;
boolean powerDetected = 0;
boolean collectorIsOn = 0;
int DC_spindown = 3000;
//allow vacuum system to run after tool is turned off
const int NUMBER_OF_TOOLS = 3;
const int NUMBER_OF_GATES = 3;
String tools[NUMBER_OF_TOOLS] = {"#1","#2","#3"};
int voltSensor[NUMBER_OF_TOOLS] = {A0,A1,A2};
long int voltBaseline[NUMBER_OF_TOOLS] = {0,0,0};
//Set the throw of each gate separately, if needed
int gateMinMax[NUMBER_OF_GATES][2] = {
/*close, open*/
{230,375},//#1
{195,410},//#2
{250,400},//#3
//keep track of gates to be toggled ON/OFF for each tool
int gates[NUMBER_OF_TOOLS][NUMBER_OF_GATES] = {
{1,0,0},
{0,1,0},
{0,0,1},
const int dustCollectionRelayPin = 11;
const int manualSwitchPin = 12; //for button activated gate, currently NOT implemented
int mVperAmp = 100; // use 100 for 20A Module and 66 for 30A Module
double ampThreshold = .20;
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
//button debouncing
int state = HIGH; // the current state of the output pin
int reading; // the current reading from the input pin
int previous = LOW; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 200; // the debounce time, increase if the output flickers
void setup(){
pinMode(dustCollectionRelayPin,OUTPUT);
pwm.begin();
pwm.setPWMFreq(60); // Default is 1000mS
//record baseline sensor settings
//currently unused, but could be used for voltage comparison if need be.
for(int i=0;i<NUMBER_OF_TOOLS;i++){
pinMode(voltSensor[i],INPUT);
voltBaseline[i] = analogRead(voltSensor[i]);
void loop(){
// use later for button debouncing
reading = digitalRead(manualSwitchPin);
if (reading == HIGH && previous == LOW && millis() - time > debounce) {
if (state == HIGH){
state = LOW;
buttonTriggered = false;
} else{
state = HIGH;
buttonTriggered = true;
time = millis();
previous = reading;
Serial.println("----------");
//loop through tools and check
int activeTool = 50;// a number that will never happen
if( checkForAmperageChange(i)){
activeTool = i;
exit;
if( i!=0){
if(checkForAmperageChange(0)){
activeTool = 0;
exit;
if(activeTool != 50){
// use activeTool for gate processing
if(collectorIsOn == false){
//manage all gate positions
for(int s=0;s<NUMBER_OF_GATES;s++){
int pos = gates[activeTool][s];
if(pos == 1){
openGate(s);
closeGate(s);
delay(2500);
//delay added to allow gates to open before vacuum system comes on
turnOnDustCollection();
} else{
if(collectorIsOn == true){
delay(DC_spindown);
turnOffDustCollection();
boolean checkForAmperageChange(int which){
Voltage = getVPP(voltSensor[which]);
VRMS = (Voltage/2.0) *0.707;
AmpsRMS = (VRMS * 1000)/mVperAmp;
Serial.print(tools[which]+": ");
Serial.print(AmpsRMS);
Serial.println(" Amps RMS");
if(AmpsRMS>ampThreshold){
return true;
}else{
return false;
void turnOnDustCollection(){
Serial.println("turnOnDustCollection");
digitalWrite(dustCollectionRelayPin,1);
collectorIsOn = true;
void turnOffDustCollection(){
Serial.println("turnOffDustCollection");
digitalWrite(dustCollectionRelayPin,0);
collectorIsOn = false;
float getVPP(int sensor)
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
int minValue = 1024; // store min value here
uint32_t start_time = millis();
while((millis()-start_time) < 500) //sample for 1 Sec
readValue = analogRead(sensor);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
// Subtract min from max
result = ((maxValue - minValue) * 5.0)/1024.0;
return result;
void closeGate(uint8_t num){
Serial.print("closeGate ");
Serial.println(num);
pwm.setPWM(num, 0, gateMinMax[num][1]);
void openGate(uint8_t num){
Serial.print("openGate ");
pwm.setPWM(num, 0, gateMinMax[num][0]);
delay(100);
pwm.setPWM(num, 0, gateMinMax[num][0]-5);
On the line that says set the throw of the gate separately,if needed, What do the numbers actually represent? I have the servos working by using the original code and just changing the numbers. I know it isnt exactly right because one of the servos is getting hot. When I get done with the project, it will have 8 servos.I started doing the wiring yesterday. I have the brackets made for the servos. The only thing I need to finish is a little time and a explanation of the numbers for the servo position.
Hopefully I posted the code correctly this time.
