Topic: Automated Dust Collection (Read 4178 times) previous topic - next topic
gladewater2016
wvmarle
Then how about following the suggestion from quite a few posts ago to post the output you see on the Serial monitor (between CODE tags!) around the time you switch on the tool. That could be quite helpful in trying to follow what's happening in that code.
Quality of answers is related to the quality of questions. Good questions will get good answers. Useless answers are a sign of a poor question.
gladewater2016
wvmarle
Just copy/paste from the Serial monitor.
dave-in-nj
I have to hit the scroll box to stop scrolling, then hit 'crtl a' to select then 'ctrl c' to copy
gladewater2016
Miter Saw: 0.07 Amps RMS
Table Saw: 4.02 Amps RMS
Band Saw: 4.24 Amps RMS
openGate 0
openGate 1
closeGate 2
openGate 3
closeGate 4
closeGate 5
turnOnDustCollection
Table Saw: 3.83 Amps RMS
Band Saw: 4.05 Amps RMS
Miter Saw: 5.43 Amps RMS
Table Saw: 4.19 Amps RMS
Miter Saw: 5.40 Amps RMS
Band Saw: 4.62 Amps RMS
Miter Saw: 5.36 Amps RMS
Table Saw: 4.37 Amps RMS
Band Saw: 4.11 Amps RMS
Table Saw: 4.38 Amps RMS
Band Saw: 4.15 Amps RMS
groundFungus
it isnt sending a signal to the relay to turn the dust collector on.
Is this still the issue?
I wired up a test circuit on my Uno and ran the code from post #6.  I used a LED on pin 11 to watch the dust collector relay output.  When one of the analog inputs goes high the LED does turn on and then LED turns off, after a delay, when the  input is brought low.  So, the code seems to be working.  If the relay is not turning on it is looking like a hardware problem.
You will save everyone's time if you read and follow the forum guidelines.  https://forum.arduino.cc/index.php/topic,148850.0.html
gladewater2016
Ok. Stupid question. Does the led go on pin 11 and ground
gladewater2016
I connected a led to pin 11 and ground. The led came on as soon as I connected it
groundFungus
#39
May 18, 2018, 08:04 pm Last Edit: May 18, 2018, 08:04 pm by groundFungus
Are all of the analog inputs that you are using at near 0V?  If any are floating (or high) that could turn on the LED.
adwsystems
@gladewater2016, any chance of posting pictures of your setup?
gladewater2016
I added a picture of my setup.
wvmarle
Why no power for the Arduino? They don't tend to work well without.
gladewater2016
woops. Power now
gladewater2016
sorry. uploaded wrong pic
