Topic: which pin is it as a output for this 1 Mhz clock (Read 917 times) previous topic - next topic
ED201
I found this nice code,  I cannot find which pin on arduino due or it simply does not work
/***               1MHz/ 50% Duty cycle PWM thru TIOA0                      ***/
/*************  Timer Counter 0 Channel 0 to generate PWM pulses thru TIOA0  ************/
  PMC->PMC_PCER0 |= PMC_PCER0_PID27;                      // Timer Counter 0 channel 0 IS TC0, TCO power ON
  PMC->PMC_PCER0 |= PMC_PCER0_PID12;                      // PIOB power ON, page 38
  PIOB->PIO_PDR |= PIO_PDR_P25;
  PIOB->PIO_ABSR |= PIO_ABSR_P25;                        // PB25 is driven by the TC, peripheral type B, page 858
  TC0->TC_CHANNEL[0].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK1  // MCK/2, clk on rising edge
                              | TC_CMR_WAVE               // Waveform mode
                              | TC_CMR_WAVSEL_UP_RC        // UP mode with automatic trigger on RC Compare
                              | TC_CMR_ACPA_CLEAR          // Clear TIOA0 on RA compare match
                              | TC_CMR_ACPC_SET;           // Set TIOA0 on RC compare match
  TC0->TC_CHANNEL[0].TC_RC = 42;  //<*********************  Frequency = (Mck/2)/TC_RC  = 1 MHz
  TC0->TC_CHANNEL[0].TC_RA = 21;  //<********************   Duty cycle = (TC_RA/TC_RC) * 100 = 50 %
  TC0->TC_CHANNEL[0].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC0 counter and enable
ard_newbie
What is the most relevant document to find pinouts ?
ED201
on the pin layout I see that it might be AD0, A7
but nothing there when I connect osciloscope.
ard_newbie
You must be the only one to see TIOA0 on A7/AD0 !!!
ED201
now i see on pin 2, If I was as good as you I wouldn't ask
I use already this pin for TFT screen
would it be possible to move to another pin like analog pins A8, A9 etc
or maybe on one of the 36 pin panel I see it also have the PWM pins
ard_newbie
You can use TIOA1 as well, but you will have to modify the sketch. TIOA1 is output by Timer Counter 0 Channel 1, and the pin is PA2:
Code: [Select]
/***               1MHz/ 50% Duty cycle PWM thru TIOA1                      ***/
  PMC->PMC_PCER0 |= PMC_PCER0_PID28;                      // Timer Counter 0 channel 1 IS TC0, TC1 power ON, page 38
  PIOA->PIO_PDR |= PIO_PDR_P2;
  PIOA->PIO_ABSR &= ~PIO_PA2A_TIOA1;                      // PA2 is driven by the TC, peripheral type A, page 858
  TC0->TC_CHANNEL[1].TC_CMR = TC_CMR_TCCLKS_TIMER_CLOCK1  // MCK/2, clk on rising edge
                              | TC_CMR_ACPA_CLEAR          // Clear TIOA1 on RA compare match
                              | TC_CMR_ACPC_SET;           // Set TIOA1 on RC compare match
  TC0->TC_CHANNEL[1].TC_RC = 42;  //<*********************  Frequency = (Mck/2)/TC_RC  = 1 MHz
  TC0->TC_CHANNEL[1].TC_RA = 21;  //<********************   Duty cycle = (TC_RA/TC_RC) * 100 = 50 %
  TC0->TC_CHANNEL[1].TC_CCR = TC_CCR_SWTRG | TC_CCR_CLKEN; // Software trigger TC0 counter and enable
ED201
Thanks I see nice 1 Mhz square on analog 7 pin
