Topic: Wemos A0 does not read voltage (Read 11864 times) previous topic - next topic
srozemuller
Thank you all for you're respone. I will check the soldering tonight and will post a clear picture (sorry missed that request).
The whole situation is soldered already. So im not able to use a breadboard anymore.
PaulRB
The purpose of a breadboard is to test a circuit and check it works before you solder everything. If any of the components are faulty, you can easily swap them out.
srozemuller
I know, this is some additional functionality i didn't think of in the first place.
PaulRB
Oh, you were not using the A0 pin before.
Hopefully it's just faulty wiring. The fact that the analog input works connected to some points in the circuit and not others points to that.
srozemuller
Ok guys, it took some while. Very busy with moving to an another place. But finally had some time to troubleshoot. It was a poor connection to the A0. Now it is working fine.
Thank you al for your feedback. Learned a lot.
dimare_gabriele
hello, could I see the code you used to read the battery voltage? at the end what was the correct circuit?
