Topic: Help with sketch please (Read 181 times) previous topic - next topic
lifeofbrian
I tried the original sketch from the Arduino tutorial page, but added four more LEDs on pins on 8 9 10 11 on my pro mini. I thought I could just add the pins in the code, but that didn't work, then I changed the (count=0;count<6;count++) to (count=0;count<10;count++) thinking that was the LED count, but still only the original 6 LEDs are working.
Original Sketch:
Code: [Select]
/* Knight Rider 3
 * This example concentrates on making the visuals fluid.
 * (cleft) 2005 K3, Malmo University
 * @author: David Cuartielles
 * @hardware: David Cuartielles, Aaron Hallborg
int pinArray[] = {2, 3, 4, 5, 6, 7};
int count = 0;
int timer = 30;
void setup(){
  for (count=0;count<6;count++) {
    pinMode(pinArray[count], OUTPUT);
  for (count=0;count<5;count++) {
   digitalWrite(pinArray[count], HIGH);
   delay(timer);
   digitalWrite(pinArray[count + 1], HIGH);
   delay(timer);
   digitalWrite(pinArray[count], LOW);
   delay(timer*2);
  for (count=5;count>0;count--) {
   delay(timer);
   digitalWrite(pinArray[count - 1], HIGH);
   delay(timer);
   delay(timer*2);
My tweaked code:
Code: [Select]
/* Knight Rider 3
int pinArray[] = {2, 3, 4, 5, 6, 7, 8, 9, 10, 11};
int count = 0;
int timer = 30;
void setup(){
  for (count=0;count<10;count++) {
   delay(timer);
   delay(timer);
   delay(timer*2);
   delay(timer);
   delay(timer);
   delay(timer*2);
slipstick
Try changing the counts in loop() not just in setup().
Steve
lifeofbrian
That worked, cheers.
Steve
