Topic: Using RS-485 boards in a project (Read 341 times) previous topic - next topic
adwsystems
May 21, 2018, 07:17 pm Last Edit: May 21, 2018, 09:28 pm by adwsystems
Is it my imagination or are these boards a pain to incorporate into a final project
Especially, noting the Vcc and Ground are on the incoming cable side (along with the 0.1" connections for A and B). It would be easier if Vcc/GND was on the Di/Ro side.
Am I looking at this wrong? Is there an easier way?
Paul_KD7HB
If your mother board is designed properly, there is no problem.'
Paul
adwsystems
Paul
Provided you had a motherboard. It would have to be custom to accept this module. If I was building a board, I would just design this as part of it (including removable bus idle and termination resistors).
But to use it as is??? They don't even have mounting holes.  :o
Paul_KD7HB
It is designed to be plugged into a mother board. No mounting holes needed.
Paul
noiasca
I confirm, they are working quite ok as "daughter boards" on a mainboard.
DE: Wie man Fragen postet:
1. was hat man (Sketch und Hardware)
2. was SOLL es machen
3. was macht es: IST (Fehlverhalten, Fehlermeldungen, Serial.Output ...)
4. Eine Frage stellen bzw. erklären was man erwartet
adwsystems
Looks like I screwed that purchase. I haven't been able to find any premade boards that accept these, let alone an Arduino shield that accepts them. All of the RS485 shields I have found only route the TX/RX lines to pins 0 and 1. That doesn't help me either as I'm either using a Mega and Serial 1 or Nano/Uno and a software serial port.
Well, I'm off to go build another shield.
horace
I have soldered these RS485 shields into breadboards together with Arduino Pros and other components etc
SamIAm93
I use the sparkfun ones, they're nicer
adwsystems
#8
May 25, 2018, 02:49 pm Last Edit: May 25, 2018, 02:50 pm by adwsystems
Nicer is relative. Maybe easier to work with, but they don't have the line idle resistors and a few other features these do.
The DFRobot shield is really nice...also really expensive (in comparison).
One definitely has to weight the trade-offs.
