Topic: rf24, network.write stop code (Read 223 times) previous topic - next topic
alb12
Hello,
I have an attiny and a nrf24l01.
I had attach interrupt on a pin for wall switch, when the interrupt is execute I run a " network.write ".
Problem, when the parent node is off, the code stop and need to reboot the attiny.
Exemple :
0 parent node
1 child node
interrupt on child 1 => try to send infomation to parent 0.
Parent 0 is off => child 1 failed and need to reboot.
Could you help me, for if parent 0 is off the child 1 continue his code.
Thank you
Robin2
Not without seeing your program code.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
alb12
#2
May 22, 2018, 04:55 pm Last Edit: May 22, 2018, 04:57 pm by alb12
Code: [Select]
const uint16_t this_node = 031;
const uint16_t other_node = 0;
#include <RF24.h>
#include <RF24Network.h>
#include <PinChangeInterrupt.h>
#define relay 9
  radio.begin();
  radio.setDataRate(RF24_250KBPS);
  network.begin(this_node);
  attachPCINT(digitalPinToPCINT(1), changeState, CHANGE);
  pinMode(relay, OUTPUT);
  SendDataRF24(relay, 0, 0, other_node, 1);
  network.update();
void SendDataRF24(int pin, int value, int etat, int other_node,  int type = -99)
 payload_t payload = { pin, value, etat, type };
 RF24NetworkHeader header( other_node,  't');
 network.write(header, &payload, sizeof(payload));
void changeState()
  int val = !digitalRead(relay);
  digitalWrite(relay, val);
  SendDataRF24(relay, val * 100, val, other_node, 1);
First change on pin attached to interrupt execute this (
Code: [Select]
 ) and after stop.
If I disable
Code: [Select]
 of changeState() it's ok.
The problem exist only if the parent is not running
Robin2
I have never used the Network library myself - just the RF24 library.
My guess is that the problem is due to sending the message from inside an ISR. I suggest you change your program to this
Code: [Select]
  network.update();
  if (newData == true) {
      newData = false;
void changeState()
  newData = true;
You will also need these definitions at the top of the program
Code: [Select]
volatile byte val;
boolean newData = false;
...R
alb12
Yes this fix the bug but how make for this work in ISR
Code: [Select]
  network.update();
      newData = false;
Robin2
Don't.
That is not what an ISR is for.
...R
