Topic: Automatic packaging machine (Read 1 time) previous topic - next topic
Chaperone
Hie guys
I am developing a simple automatic packaging machine which you key in the quantity you want to measure then a valve is opened to allow the liquid into a plastic while measuring and closes the valve when weight on the scale is equal to desired weight. My problem now is on having a program to control my motorised valve so that as the difference between the desired weight and the measured weight is reduced the valve will also be closing accordingly.
I am stuck.
I am using load cells for my scale and a 12v motorised valve for my dispensing control
Chaperone
Hie guys
I am stuck.
vinceherman
#2
May 24, 2018, 10:29 pm Last Edit: May 24, 2018, 10:29 pm by vinceherman
I sometimes pre-pay at the fuel pump.  I tell the station attendant the amount I want and they enter it into the pump control software (the register).
The pump starts out running at full volume.  But as the pump approaches the full purchase amount, it slows to a trickle.  Then it shuts off right at the full purchase amount.
This slow down before shutdown increases the accuracy.
Paul_KD7HB
Hie guys
I am stuck.
How much time is required for your motorized valve to open and close?
Paul
jremington
Quote
I am stuck.
Doing what, and why?
Coding Badly
@Chaperone, do not cross-post.  Threads merged.
Elleder
Hey, does your problem solved?
I find i also meet this problem.
