I am using Arduino Mega board in my project. I solder Arduino to perfboard with headers. At first, I measure resistance between 5V and Gnd pins in mega ohms. After soldering some transistors and IC sockets on perfboard, today I realized that the resistance between 5V pin and Gnd pin is approximately 1.6 kohm. I always measure without powering the board.
In my project I use 15 other ICs and transistors. Their Vcc and Gnd pin will be also connected to the 5V and Gnd pins of Arduino. Therefore, it is critical for me to be sure about whether there is a problem or not because also these ICs can be damaged also.
5V / 1.6kohm = 3.125 mA
Is this resistance is an expected value? Or is the current flows through power pins cause a damage to the board?
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.htmlThe reason that the resistance between 5V and gnd is going down is
because of the ICs and other components that you are wiring into the circuit.
When you measure resistance, your DMM places a voltage across its probes and it measures the current that flows, this is converted to resistance, using OHMs Law.
As you add components to your circuit, you add more components for this current to flow.
Every time you add a component between 5V and gnd, you are adding another component in PARALLEL with the supply, so the resistance drops.
It is good practice to measure resistance from 5V to gnd, if you are building a circuit, it means you can check for shorts.
As you learn electronics you will learn to accept these sorts of readings, when you look at your circuit and consider the components you are adding
Can you please tell us your electronics, programming, Arduino, hardware experience?
Thanks.. Tom..
