Topic: Building H-Bridge with MOSFETs - P-Channel question (Read 2084 times) previous topic - next topic
kimmjoe
Alright, now I got almost all the info I need to make my big order ;)
I got one more question about freewheeling diodes. Both' FETs datasheets speak about body diode characteristics, so do these have freewheeling diodes built-in? Or should I add external ones as well? If so, which ones? I got loads of n4001 lying around, but I guess 1A is not enough, even though it will be only for a splitsecond, right? Or shoul I go for Zeners (which)?
MarkT
Power MOSFETs happen to have body diodes as an integral part of their high-current handling structure.
If, and only if, you have a bridge with both high and low-side MOSFETs, each one can be the diode
for the other.  If you only have a single switching MOSFET, the load will need a diode across it, since
the MOSFET diode is no use in that situation.
For more efficiency you can add schottky external diodes.
kimmjoe
#17
May 31, 2018, 03:39 pm Last Edit: May 31, 2018, 04:20 pm by kimmjoe
I made a schematic, please dont laugh, its my first time with KiCAD...
I'm not sure about the Resistors between 12V and the GATES. should these be different on the P and N Channel FETs?
Also, how to determine the Value for these Resistors?
MorganS
You don't need those diodes. Look inside the mosfet symbols to see the body diodes.
The resistors must charge the mosfet inherent gate capacitance quickly enough to support your PWM speed. The gate capacitance is complex but the datasheet should give you a headline number to work with.
Or copy the resistor value from someone else's similar project.
"The problem is in the code you didn't post."
kimmjoe
#19
May 31, 2018, 06:05 pm Last Edit: May 31, 2018, 06:25 pm by kimmjoe
What about the position of the resistor? From what I saw here: http://www.bristolwatch.com/ele2/mosfet_relay.htm
the ones on the HIGH Side are right, but on the LOW site, they need to go between GATE an SOURCE, is that correct?
I edited it on the right side in the new schematic, so you can see what I mean.
How would I calculate the value? Datasheets mention "Input Capacitance", "Coss Output Capacitance", "Crss Reverse Transfer Capacitance" and "Drain to Sink Capacitance".
So the gate and the resistor form an RC network, which is bad for fast switching, but what equation gives me the ideal value for R?
kimmjoe
From what I gather, the higher the resistance, the slower the rise and fall times of the FET will get.
But there has to be a certain amount of resistance to protect the transistor in the opto isolator.
So, in order to be able to PWM it, resistance has to be as low as possible to make the FET as fast as possible.
The 817 transistor's maximum collector current is 50 mA. This means R = U / I ->> 12V / 0.05 A = 240 Ohm. But I don't want to drive the transistor at maximum, so I could double or quadruple and try 500 or 1k Ohm.
Is that correct?
Wawa
Try calculating the resistors the other way.
You have 20mA (40mA absolute max) available from an Arduino pin.
Vf of the opto's IR LED is ~1.3volt, so 5-1.3= ~3.7volt across the LED's current limiting resistor.
CL resistor value is 3.7/0.02= ~185ohm.
Standard value of 180ohm will do.
Worst case CTR (current transfer ratio) of a PC817 is 50%, so 10mA transistor current available.
You want full swing of the collector at 12volt/10mA.
Collector resistor minimum value with worst case PC817 = 12/0.01 = 1200 = 1k2.
Let's hope the PC817s are not that bad, so use 1k.
Where to put the opto transistor. As in the diagram for Q3 or for Q4.
Not conducting transistor is almost ideal open circuit, but conducting has a saturation voltage.
Fet Vgs 'off' voltage range is small, but Vgs for 'on' can be anything between 6volt and 12volt.
I think it's therefore better to have the resistors between gate and source, and the transistor between gate and ground/12volt.
Leo..
Wawa
Possible parts reduction.
The four schottky diodes, as axplained by MarkT (post#16).
Two Arduino pins instead of four.
The opto LEDs for Q1 and Q4 can be driven by one Arduino pin, by connecting the LEDs in series.
The single CL resistor for the two LEDs must be reduced to 100 or 120ohm to keep LED current the same.
Same for the Q2, Q3 pair.
If the supply is at least 12volt, then you might be able to get away with only two optocouplers.
Connect one opto transistor between the gate of Q1 and the gate of Q4.
Gate to ground resistor for Q4 must have a slightly lower value than the gate to 12volt resistor for Q1.
Because one is fet is logic level, and the other one is not. 470ohm+560ohm could be ok.
Leo..
kimmjoe
#23
Jun 01, 2018, 08:15 am Last Edit: Jun 01, 2018, 08:17 am by kimmjoe
Hey Wawa, thank you for your input! Woulnd I need another logic invertng transistor to do that? My understanding is, that the high side FETs conduct, when no voltage is applied, while the low side ones conduct when voltage is applied. So I would need to invert one, if I were to drive them diagonally with one signal.
Anyway, it would safe me only about 50ct for optos and resistors and I got enough I/O pins to spare on the Nano. Another thing is what would happen if I were to use PWM in that configuration, since high and low side FETs have different characteristics, maybe it would mess up PWM even more...?
My Idea was to turn on the High side and apply PWM to the other to avoid that.
Im hoping that I'll get the parts this weekend so that I can put it all together and do some mesuring on Monday.
I will let you know how it turns out!
kimmjoe
Leo..
Ao you're saying i should rather do it like I drew it on O3 rather than how I drew it on Q4?
MorganS
Yes, that is a common method.
No, like Q4. The mosfet is off when Vgs is near zero. Many have threshold voltages as low as 1.4V so your opto on Q3 has to work hard in saturation mode to get its voltage that low.
The opto on Q4 is off to turn the mosfet off. The resistor will (eventually) discharge the gate capacitor to zero volts.
You should test the voltages on these drivers before hooking up the mosfets. I expect that either arrangement will work unless the optos are using an internal Darlington topology or something weird.
kimmjoe
#26
Jun 01, 2018, 07:07 pm Last Edit: Jun 01, 2018, 07:13 pm by kimmjoe
Thanks for that clarification! I edited my schematic accordingly. Maybe you could have final look, before I solder it all on a hole grid board ;)
Oh, btw I left the diodes in there, because ... well I ordered them and I guess my teacher will like additional safety measures. I got SB530 which are in DO-201 packages, they're so huuuge!! ;) I like components that look like they can take couple of Amps ;)
