Topic: Network settings web page FORM using EEPROM to save submit [DONE] (Read 58206 times) previous topic - next topic
sakugava
Update to compile with Arduino 1.6.4 / 1.6.5.
Read this to understand the modifications
sakugava
In my last post I uploaded a sketch that I use with the ENC28J60 ethernet controller. If you want to use with the WIZ5100 controller (the Arduino official one), just change the line #include <UIPEthernet.h> to #include <Ethernet.h>.
technofreek
Hello,
I was able to compile in installed IDE (Not stand alone file) ver 1.0.5-r2, using UIPEthernet library.
successfully compiled EthernetSetup1_1 , will be adding more options like selct DHCP and STATIC.
There is a bug in MAC address field. Eg mac: 00:02:8A:FE:0F , leading zeros are omited.
Any one has a fix ?
One more issue I am running into:
After I add some html code in
Code: [Select]
prog_char htmla0 and
Code: [Select]
prog_char htmla1  it does not save first two digits of mac address.
Thanks
Sudheer
~suds~
JO3RI
Hi, It has been a long time since I visited this forum (very long)
Nice to see people kept working on the code.
Leading zero's is a problem indeed, "posting" a zero = to posting nothing. To be honest, I don't have a clue on how to fix it.
http://www.JO3RI.be
Nederlandstalige sectie - http://arduino.cc/forum/index.php/board,77.0.html -
overdrive69
Hello,
to reset the Arduino from Software i use this
https://github.com/WickedDevice/SoftReset/tree/e73cf5af75f790e6ff85f9e89ecf3de42e530293
So now everytime i press submit it resets the Arduino if there where some changes in the settings.
Edit: At the moment it only works with ip changes, not with Mac changes
mcnobby
Hi I am also using the basic front end of this project for my own..
I made a few discoveries...
Instead of going mad with using progmem to store the HTML, you can use Macro F
Code: [Select]
client.println(F("HTTP/1.1 200 OK")); //send new page
client.println(F("Content-Type: text/html"));
client.println(F("Connection: close"));  // the connection will be closed after completion of the response
really neatens things up for you ...
Also I was wondering about this soft restart...
I was thinking you could call up a line of assembler that would basically do a direct jump to the program start vector...
http://www.youtube.com/user/Recovered
http://www.smartshow.lighting
mcnobby
Im really pleased with mine so far, in the end mine is a long way from where I started with the code on here, it uses some nice simple CSS, JS and DOM
xyzbilal
hello everyone,
in addition to this project I want to form this project to setup server address
which is I want to post sensor data to. but I could not manage to change  an store in eeprom web server information which is stored as default string value.  anybody can help me to solve this issue..
thanks for help..
mcnobby
I saw something on-line about how to do this, I shall try and find the link for it...
tushar19
Need help...
Anyone has modified the code for another server entry i.e.
MAC,IP,GW,MASK,SERVER1 on to the webpage.
I tried but the the submit is having some issue-the previous data displays after submitting new!
As I don't know html coding I tried tweaking JO3RI first post code.
TIA.
Dias1
For Server use this:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xAA, 0xFE, 0xAE }; //assign arduino mac address
byte ip[] = {192, 168, 0, 177 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 0, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
byte serverName[] = { 192, 168, 0, 101 }; // (IP)  web page server IP address
byte dnsserver[] = {192,168,0,1};        //-------------------
EthernetServer server(80); //server port arduino server will use
// This is the HTML code all chopped up. The best way to do this is, is by typing
// your HTML code in an editor, counting your characters and divide them by 8.
// you can chop your HTML on every place, but not on the \" parts. So remember,
// you have to use \" instead of simple " within the HTML, or it will not work.
const char htmlx0[] PROGMEM = "<html><title>Arduino Ethernet Setup Page</title><body marginwidth=\"0\" marginheight=\"0\" ";
const char htmlx1[] PROGMEM = "leftmargin=\"0\" style=\"margin: 0; padding: 0;\"><table bgcolor=\"#999999\" border";
const char htmlx2[] PROGMEM = "=\"0\" width=\"100%\" cellpadding=\"1\" style=\"font-family:Verdana;color:#fff";
const char htmlx3[] PROGMEM = "fff;font-size:12px;\"><tr><td>&nbsp Arduino Ethernet Setup Page</td></tr></table><br>";
PROGMEM const char* const string_table0[] = {htmlx0, htmlx1, htmlx2, htmlx3};
const char htmla0[] PROGMEM = "<script>function hex2num (s_hex) {eval(\"var n_num=0X\" + s_hex);return n_num;}";
const char htmla1[] PROGMEM = "</script><table><form><input type=\"hidden\" name=\"SBM\" value=\"1\"><tr><td>MAC:";
const char htmla2[] PROGMEM = "<input id=\"T1\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT1\" value=\"";
const char htmla3[] PROGMEM = "\">.<input id=\"T3\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT2\" value=\"";
const char htmla4[] PROGMEM = "\">.<input id=\"T5\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT3\" value=\"";
const char htmla5[] PROGMEM = "\">.<input id=\"T7\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT4\" value=\"";
const char htmla6[] PROGMEM = "\">.<input id=\"T9\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT5\" value=\"";
const char htmla7[] PROGMEM = "\">.<input id=\"T11\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT6\" value=\"";
PROGMEM const char* const string_table1[] = {htmla0, htmla1, htmla2, htmla3, htmla4, htmla5, htmla6, htmla7};
const char htmlb0[] PROGMEM = "\"><input id=\"T2\" type=\"hidden\" name=\"DT1\"><input id=\"T4\" type=\"hidden\" name=\"DT2";
const char htmlb1[] PROGMEM = "\"><input id=\"T6\" type=\"hidden\" name=\"DT3\"><input id=\"T8\" type=\"hidden\" name=\"DT4";
const char htmlb2[] PROGMEM = "\"><input id=\"T10\" type=\"hidden\" name=\"DT5\"><input id=\"T12\" type=\"hidden\" name=\"D";
const char htmlb3[] PROGMEM = "T6\"></td></tr><tr><td>IP: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT7\" value=\"";
const char htmlb4[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT8\" value=\"";
const char htmlb5[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT9\" value=\"";
const char htmlb6[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT10\" value=\"";
PROGMEM const char* const string_table2[] = {htmlb0, htmlb1, htmlb2, htmlb3, htmlb4, htmlb5, htmlb6};
const char htmlc0[] PROGMEM = "\"></td></tr><tr><td>MASK: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT11\" value=\"";
const char htmlc1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT12\" value=\"";
const char htmlc2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT13\" value=\"";
const char htmlc3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT14\" value=\"";
PROGMEM const char* const string_table3[] = {htmlc0, htmlc1, htmlc2, htmlc3};
const char htmld0[] PROGMEM = "\"></td></tr><tr><td>GW: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT15\" value=\"";
const char htmld1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT16\" value=\"";
const char htmld2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT17\" value=\"";
const char htmld3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT18\" value=\"";
PROGMEM const char* const string_table4[] = {htmld0, htmld1, htmld2, htmld3};
const char htmle0[] PROGMEM = "\"></td></tr><tr><td>Server: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT19\" value=\"";
const char htmle1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT20\" value=\"";
const char htmle2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT21\" value=\"";
const char htmle3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT22\" value=\"";
const char htmle4[] PROGMEM = "\"></td></tr><tr><td><br></td></tr><tr><td><input id=\"button\"type=\"submit\" value=\"SUBMIT\" ";
const char htmle5[] PROGMEM = "></td></tr></form></table></body></html>";
PROGMEM const char* const string_table5[] = {htmle0, htmle1, htmle2, htmle3, htmle4, htmle5};
const char htmlf0[] PROGMEM = "Onclick=\"document.getElementById('T2').value ";
const char htmlf1[] PROGMEM = "= hex2num(document.getElementById('T1').value);";
const char htmlf2[] PROGMEM = "document.getElementById('T4').value = hex2num(document.getElementById('T3').value);";
const char htmlf3[] PROGMEM = "document.getElementById('T6').value = hex2num(document.getElementById('T5').value);";
const char htmlf4[] PROGMEM = "document.getElementById('T8').value = hex2num(document.getElementById('T7').value);";
const char htmlf5[] PROGMEM = "document.getElementById('T10').value = hex2num(document.getElementById('T9').value);";
const char htmlf6[] PROGMEM = "document.getElementById('T12').value = hex2num(document.getElementById('T11').value);\"";
const char htmlf7[] PROGMEM = "\"></td></tr><tr><td><br></td></tr><tr><td><input id=\"button\"type=\"button\" onmousedown=location.href=\"/index.html\"  value=\"HOME\" ";
PROGMEM const char* const string_table6[] = {htmlf0, htmlf1, htmlf2, htmlf3, htmlf4, htmlf5, htmlf6, htmlf7};
const byte ID = 0x92; //used to identify if valid data in EEPROM the "know" bit,
// if this is written in EEPROM the sketch has ran before
// We use this, so that the very first time you'll run this sketch it will use
// the values written above.
// defining which EEPROM address we are using for what data
Dias1
void setup(){
ShieldSetup (); //Setup the Ethernet shield
// Ethernet.begin(mac,ip,gateway,gateway,subnet);
// Ethernet.setRetransmissionTimeout(50);  // set the Ethernet controller's timeout to 50 ms
server.begin();
//Serial.println("server/client 1.0 test 7/03/12"); // keep track of what is loaded
//Serial.println("Send an g in serial monitor to test client"); // what to do to test client
Serial.print("local IP is  ");
Serial.println(Ethernet.localIP());
Serial.print("local MAC is  ");
Serial.print(mac[0],HEX);
Serial.print(":");
Serial.print(mac[1],HEX);
Serial.print(":");
Serial.print(mac[2],HEX);
Serial.print(":");
Serial.print(mac[3],HEX);
Serial.print(":");
Serial.print(mac[4],HEX);
Serial.print(":");
Serial.println(mac[5],HEX);
Serial.print("remote server's IP is  ");
Serial.print(serverName[0],DEC);
Serial.print(".");
Serial.print(serverName[1],DEC);
Serial.print(".");
Serial.print(serverName[2],DEC);
Serial.print(".");
Serial.println(serverName[3],DEC);
Serial.print("the gateway is  ");
Serial.print(gateway[0],DEC);
Serial.print(".");
Serial.print(gateway[1],DEC);
Serial.print(".");
Serial.print(gateway[2],DEC);
Serial.print(".");
Serial.println(gateway[3],DEC);
Serial.print("the subnet is  ");
Serial.print(subnet[0],DEC);
Serial.print(".");
Serial.print(subnet[1],DEC);
Serial.print(".");
Serial.print(subnet[2],DEC);
Serial.print(".");
Serial.println(subnet[3],DEC);
Serial.print("local server Port is  ");
Serial.print(serverport[0],HEX);
9H1LO
has there been any further development with this ? or a new library exists ? looking for a setup page which such as this with ability to setup static or dhcp and server address stored in eeprom and compilable on 1.8+ as these example need lots of tweaks....got the first examples from JO3RI (is it a ham call ??) working but would like to have the dhcp & server address option but he seems to have abandoned the code
ismail-saeid
Thanks' JO3RI for share your knowledge you are a unique.
and thanks' all, that is big work.
I need to help, I want to create the same project but using the ESP8266 NodeMCU what is the difference in the code??
