For Server use this:
byte mac[] = {0xDE, 0xAD, 0xBE, 0xAA, 0xFE, 0xAE }; //assign arduino mac address
byte ip[] = {192, 168, 0, 177 }; // ip in lan assigned to arduino
byte gateway[] = {192, 168, 0, 1 }; // internet access via router
byte subnet[] = {255, 255, 255, 0 }; //subnet mask
byte serverName[] = { 192, 168, 0, 101 }; // (IP) web page server IP address
byte dnsserver[] = {192,168,0,1}; //-------------------
EthernetServer server(80); //server port arduino server will use
// This is the HTML code all chopped up. The best way to do this is, is by typing
// your HTML code in an editor, counting your characters and divide them by 8.
// you can chop your HTML on every place, but not on the \" parts. So remember,
// you have to use \" instead of simple " within the HTML, or it will not work.
const char htmlx0[] PROGMEM = "<html><title>Arduino Ethernet Setup Page</title><body marginwidth=\"0\" marginheight=\"0\" ";
const char htmlx1[] PROGMEM = "leftmargin=\"0\" style=\"margin: 0; padding: 0;\"><table bgcolor=\"#999999\" border";
const char htmlx2[] PROGMEM = "=\"0\" width=\"100%\" cellpadding=\"1\" style=\"font-family:Verdana;color:#fff";
const char htmlx3[] PROGMEM = "fff;font-size:12px;\"><tr><td>  Arduino Ethernet Setup Page</td></tr></table><br>";
PROGMEM const char* const string_table0[] = {htmlx0, htmlx1, htmlx2, htmlx3};
const char htmla0[] PROGMEM = "<script>function hex2num (s_hex) {eval(\"var n_num=0X\" + s_hex);return n_num;}";
const char htmla1[] PROGMEM = "</script><table><form><input type=\"hidden\" name=\"SBM\" value=\"1\"><tr><td>MAC:";
const char htmla2[] PROGMEM = "<input id=\"T1\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT1\" value=\"";
const char htmla3[] PROGMEM = "\">.<input id=\"T3\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT2\" value=\"";
const char htmla4[] PROGMEM = "\">.<input id=\"T5\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT3\" value=\"";
const char htmla5[] PROGMEM = "\">.<input id=\"T7\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT4\" value=\"";
const char htmla6[] PROGMEM = "\">.<input id=\"T9\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT5\" value=\"";
const char htmla7[] PROGMEM = "\">.<input id=\"T11\" type=\"text\" size=\"2\" maxlength=\"2\" name=\"DT6\" value=\"";
PROGMEM const char* const string_table1[] = {htmla0, htmla1, htmla2, htmla3, htmla4, htmla5, htmla6, htmla7};
const char htmlb0[] PROGMEM = "\"><input id=\"T2\" type=\"hidden\" name=\"DT1\"><input id=\"T4\" type=\"hidden\" name=\"DT2";
const char htmlb1[] PROGMEM = "\"><input id=\"T6\" type=\"hidden\" name=\"DT3\"><input id=\"T8\" type=\"hidden\" name=\"DT4";
const char htmlb2[] PROGMEM = "\"><input id=\"T10\" type=\"hidden\" name=\"DT5\"><input id=\"T12\" type=\"hidden\" name=\"D";
const char htmlb3[] PROGMEM = "T6\"></td></tr><tr><td>IP: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT7\" value=\"";
const char htmlb4[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT8\" value=\"";
const char htmlb5[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT9\" value=\"";
const char htmlb6[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT10\" value=\"";
PROGMEM const char* const string_table2[] = {htmlb0, htmlb1, htmlb2, htmlb3, htmlb4, htmlb5, htmlb6};
const char htmlc0[] PROGMEM = "\"></td></tr><tr><td>MASK: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT11\" value=\"";
const char htmlc1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT12\" value=\"";
const char htmlc2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT13\" value=\"";
const char htmlc3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT14\" value=\"";
PROGMEM const char* const string_table3[] = {htmlc0, htmlc1, htmlc2, htmlc3};
const char htmld0[] PROGMEM = "\"></td></tr><tr><td>GW: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT15\" value=\"";
const char htmld1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT16\" value=\"";
const char htmld2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT17\" value=\"";
const char htmld3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT18\" value=\"";
PROGMEM const char* const string_table4[] = {htmld0, htmld1, htmld2, htmld3};
const char htmle0[] PROGMEM = "\"></td></tr><tr><td>Server: <input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT19\" value=\"";
const char htmle1[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT20\" value=\"";
const char htmle2[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT21\" value=\"";
const char htmle3[] PROGMEM = "\">.<input type=\"text\" size=\"3\" maxlength=\"3\" name=\"DT22\" value=\"";
const char htmle4[] PROGMEM = "\"></td></tr><tr><td><br></td></tr><tr><td><input id=\"button\"type=\"submit\" value=\"SUBMIT\" ";
const char htmle5[] PROGMEM = "></td></tr></form></table></body></html>";
PROGMEM const char* const string_table5[] = {htmle0, htmle1, htmle2, htmle3, htmle4, htmle5};
const char htmlf0[] PROGMEM = "Onclick=\"document.getElementById('T2').value ";
const char htmlf1[] PROGMEM = "= hex2num(document.getElementById('T1').value);";
const char htmlf2[] PROGMEM = "document.getElementById('T4').value = hex2num(document.getElementById('T3').value);";
const char htmlf3[] PROGMEM = "document.getElementById('T6').value = hex2num(document.getElementById('T5').value);";
const char htmlf4[] PROGMEM = "document.getElementById('T8').value = hex2num(document.getElementById('T7').value);";
const char htmlf5[] PROGMEM = "document.getElementById('T10').value = hex2num(document.getElementById('T9').value);";
const char htmlf6[] PROGMEM = "document.getElementById('T12').value = hex2num(document.getElementById('T11').value);\"";
const char htmlf7[] PROGMEM = "\"></td></tr><tr><td><br></td></tr><tr><td><input id=\"button\"type=\"button\" onmousedown=location.href=\"/index.html\" value=\"HOME\" ";
PROGMEM const char* const string_table6[] = {htmlf0, htmlf1, htmlf2, htmlf3, htmlf4, htmlf5, htmlf6, htmlf7};
const byte ID = 0x92; //used to identify if valid data in EEPROM the "know" bit,
// if this is written in EEPROM the sketch has ran before
// We use this, so that the very first time you'll run this sketch it will use
// the values written above.
// defining which EEPROM address we are using for what data
