Topic: PID control with fans and ultrasonic sensor (HC_SR04) (Read 1 time) previous topic - next topic
tmrugh
I am using PID control to control the speed of a fan based on the height of an ultrasonic sensor, but for some reason, it is not supplying enough power to the fans even though I have analogWrite at 255.  However, when I just send power to the fans using analogWrite and no PWM (Basic_Control.ino), it works out just fine.  I am using an Arduino Motor Shield, a 12V 3A 3-pin fan, an Arduino UNO R3, and an Ultrasonic Sensor.  Also, when I vary the k-values for proportional, integral, and derivative control, there is no discernible difference between the control as I vary the height of the ultrasonic sensor.   Thanks in advance.
PaulS
Quote
const int trigPin = 11;   //10
const int echoPin = 12;   //13
Those comments look pretty silly.
Quote
No, you are not. Regardless of what the distance reading is, you MIGHT write 255 to the PWM pin.
Code: [Select]
if (currentMillis-prevMillis <= period)
Less than?
jremington
#2
Jun 04, 2018, 05:24 pm Last Edit: Jun 04, 2018, 05:27 pm by jremington
It might be difficult to use the same pin for motor speed and ranger control.
How did you actually wire everything up?
Code: [Select]
digitalWrite(trigPin, HIGH);
analogWrite(11, 0);     //Channel B Speed 0%
Google "PID tuning" to learn how to set the three constants. This will not work when starting out.
Code: [Select]
  double ki = 1;
  double kd = 1;
