Topic: Windows 10 - ATMega328p - Upload Error (Read 278 times) previous topic - next topic
Gyuszy
Hi. I made my own arduino from the atmega328p microcontroller. I used a CP2012 USB-TTL converter to upload the code. I tried to upload and I got this error message after a 4-5 minutes:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x94
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x94
Can someone help me ? What can i do ?
More info:
Programmer: AVRISPmkII
Board: Arduino Uno
spycatcher2k
Quote
And you are sure it is wired correctly, and the bootloader has been burned!
Quote
And you are sure it is wired correctly?
You give NO details of this magic board YOU BUILT - so what more do you expect?
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
Gyuszy
Yes. I checked the wires 5-6 times, and the controller has a bootloader. But i tried to replace my controller in the arduino uno and upload a programme. And it's Works. So i dont know what is the problem...
spycatcher2k
So it's your board then! No one but YOU can see the board, or how you have wired the USB-Serial converter, so GOOD LUCK!
Mrs Drew
Gyuszy
spycatcher2k
Where is the 10K pull up resistor for the RESET? And your GND and VCC connections on the top of the chip?
Mrs Drew
