Topic: ESP8266 with ESP-NOW as an alternative to nRF24L01+ (Read 11253 times) previous topic - next topic
Robin2
To make it easy for people to help you please modify your post and use the code button </>
so your code looks like this and is easy to copy to a text editor. See How to use the Forum
Your code is too long for me to study quickly without copying to my text editor. The text editor shows line numbers, identifies matching brackets and allows me to search for things like all instances of a particular variable or function.
Also please use the AutoFormat tool to indent your code for easier reading.
...R
Two or three hours spent thinking and reading documentation solves most programming problems.
zoomx
Using the code tag the green highlight will be lost, I believe.
Robin2
You are quite correct. But that is not an excuse for not using code tags.
A suitable comment can easily be included in a program.
...R
zoomx
