Topic: UNO Trouble uploading on XP ... not in sync/ protocol error (Read 16239 times) previous topic - next topic
karistouf
Mar 12, 2011, 10:15 pm Last Edit: Mar 12, 2011, 10:49 pm by karistouf Reason: 1
Hi, every body i m fighting to upload sketch to UNO from xp with arduino 0022
On my computer i was having 2 COM PORT showing up, despite only ONE arduino is connected
I have made a clean of all my port com, using this : http://blog.cognitioninfotech.com/2009/01/how-to-clear-or-reset-com-port.html
But i steel CANT upload any sketch;
i have the following answer from compilator:
avrdude: stk500_getsync(): not in sync: resp=0x30
avrdyde: stk500_disable(): protocol error, expect=0x14, resp=0x51
I was before using a duemillanove without any troubles, and with FTDI drivers.
Other thing important: the UNO appears in Windows Hardware panel, with its comport, but there is NO communication between apps and the UNO
The firmata exe doesnt shows up anything.
the UNO is alive and works well on another laptov with seven ( upload and job)
ANy solution ?
spycatcher2k
Mrs Drew
http://www.uk-pcb.co.uk - UK PCB Fab Company
I will design & code for you, but I will also charge you (PM me)
If you don't like my answers, realize : I'm not being cheeky, I'm Just trying to prompt you to use your own brain/google etc.
karistouf
yes indeed.
and i have only one COM PORT now showing up, selected.
acbetts
I had this same problem, all I did was update the driver software, and also check in device manager (not sure what xp calls it), then ports, and from there you can change driver software and baud rate etc..
hope this helps.
karistouf
driver software: is there one more recent than the one embedded inside arduino 0022 ?
spycatcher2k
Mrs Drew
karistouf
this one: http://arduino.cc/en/uploads/Main/ArduinoUnoFront240.jpg
I have a friend that have the same problem on an XP with a duemillanove: works fine one one computer, not at all on the other. same troubles.
we have in commun to use VCOM drivers from Enttec ( FTDI chipset) for dmx devices.
marcoce
Hi, using the arduino 1 on mac os x 10.4.11
i have quite the same message:
i have the latest driver but.. no joy! :~
karistouf
are you using other COM devices ( Enttec or FTDI products ) ?
marcoce
i use this:
FTDIUSBSerialDriver_10_4_10_5_10_6.mpkg
and arduino 022
i think it's the best on
mac os x 10.4.11 (ppc)
thanks
karistouf
karistouf
Is there any developper auround to help on this topic ?
mbanzi
hello
Arduino UNO uses the USB driver provided by Windows.
The .inf file that you find in "drivers" is just telling windows "use your standard driver"
the FTDI driver should not interfere in any way.
make sure that the UNO shows up in Device Manager and has a COM port number assigned to it.
try reinstalling the driver and point windows to the "drivers" folder inside your Arduno folder.
Follow this guide http://arduino.cc/en/Guide/UnoDriversWindowsXP
it should work well.
karistouf
Hi Massimo. First thanks for your reply and thanks for this great project that is arduino. Needs to be said, its great !
Coming back to myproblem, of course I have already followed this procedure. An I just retried just now, without any success.
The UNO is selected in the IDE, and the COMPORT also
I still have them result:$Binary sketch size is printed
and same trubles about sync and resp=0x30
protocol error: expected 0x14 resp 0x51
:smiley-eek-blue:
karistouf
hum no idea on how to solve this or understand what s going up ?
