Topic: Weatherstation with a outdoor sensor unit using XBEE and solar power. (Read 7561 times) previous topic - next topic
axel_behrens
I finished my little weatherstation project with a outdoor sensor unit using XBEE and solar power.
For more information and a photo tutorial about how to set up the units have a look here: http://tinyurl.com/6bk5bvo
Enjoy it!
Axel
graynomad
Rob Gray aka the GRAYnomad www.robgray.com
mowcius
Very neat looking.
That switch your using sure is expensive :P
I was looking at the light up ones and they're rather more than I'm willing to spend - but they do look cool :D
axel_behrens
Thanks!
I like the switch too... it's vandalism proof, costs 6,30 €. Not so much compared to the rest of the compartment.
Pauly
Nice project!  i hope to make something similar soon with one more component.
I want to also use a WiShield to send the data to a web page.
Right now I'm learnig how XBEEs work.
Was it hard to integrate the solar panel aspect of this project?
axel_behrens
Thank you!
I had some problems with the LiPoly charger, destroyed 2 of them. I suppose, the voltage from the solar panels has been to high (even so rated at 6V, input max for the charger 7V). Therefore I added a voltage regulator to keep the voltage at 5V. Otherwise the mechanical work has been the hardest. I found it hard to integrate a webserver into the system, therefore I setup a datalogger with webserver capability (see same forum).
Please present your results here in the forum! Looking forward to it.
Axel
liuzengqiang
Very cool! Where did you get that enclosure and how much?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
axel_behrens
Its a BOPLA ET-205 (4€) and ET-227 (13€), bought at www.reichelt.de
Greetings,
     Axel
liquidarts
Axel,
Am looking to build your weather station for my Opa in Furth,but am having difficulty finding a 20x4 Serial LCD. Could you point me to where you purchased it from so that I don't have to re-write the code for an I2C 20x4 LCD.
Thanks,
Martin
liuzengqiang
If you take my phi-panel and saw off the keyboard, ... ;)
http://www.inmojo.com/store/liudr-arduino-and-physics-gadgets/item/serial-20x4-lcd-keypad-panel---phi-panel/
axel_behrens
Hi Martin,
sorry for the late reply, have been on a trip.
I bought the display from www.watterott.com, part no: LCD-09568
http://www.watterott.com/de/20x4-Zeichen-LED-gelb/gruen-serielle-Ansteuerung.
But they should be available also from www.tinkersoup.de or sparkfun.
Good luck with your project.
Axel
bld
Looking good, but reading through the pdf files I noticed it says you are using li-ion batteries for the transmitter.
Isn't it li-po batteries? I got a li-po battery, looking exactly like yours, and you are also using a li-po charger for the battery.
captain-slow.dk | non contagious!
axel_behrens
Actually the battery is called polymer lithium ion - you are right!
Axel
novice
Greetings,
     Axel
Hi Axel,
what about the enclosure shown in your first post?.
"DG2AB"?
axel_behrens
DG2AB is my Ham Radio call....
The enclosure is a TEKO AUS22 bought at www.reichelt.de
Axel
