Topic: Nano fails to verify (Read 518 times) previous topic - next topic
AlbertHall
I have a Nano which fails to verify though others do verify correctly.
I attempted to program 'blink' and the LED doesn't respond correctly.
Attached is a copy of the programming messages.
Do I need a new Nano or should I attempt to reprogram the bootloader?
kprims
Quote
Try burning the bootloader if you have an Arduino or another programmer like a USBasp or USBtinyISP.
AlbertHall
I have another nano and a uno - I guess I could use either?
The board doesn't have ICSP pins soldered and if I fitted them I would have to remove them again or it won't fit on the application board.
So must I use the ICSP pins or can I connect to the equivalent pins - D11, D12, D13, RST, +5V, GND?
kprims
Quote
You can use the equivalent pins. Use the Arduino that would be easiest to hookup.
https://www.arduino.cc/en/Tutorial/ArduinoISP
AlbertHall
It doesn't want to play.  I get invalid device signature 0xFFFFFF.
Using the same board as programmer and the same connections I could program the bootloader in a Uno so I think it's time for a new Nano  :(
kprims
DrAzzy
#6
Jun 15, 2018, 08:10 am Last Edit: Jun 15, 2018, 08:11 am by DrAzzy
Device sig 0xFFFFFF can mean that MISO is shorted to Vcc (or you wired it wrong) - Doublecheck connections with your DVM before you trash the nano. Also check that all the applicable pins are connected (for example, if Gnd wasn't connected, but Vcc was, I think you'd get this result too). I recommend always doing this when there are inexplicable problems bootloading - particularly when using Arduino as ISP, since there are twice as many connection points to screw up.
(also, a trick relating to ICSP headers - if you have a cable with 2x3 connector on it, you can plug a 2x3 piece of pin header into it, put it into the holes, and hold it in place, with a gentle sideways pressure to make sure the pins make contact - that's how I bootload the boards I sell)
ATTinyCore for x4/x5/x61/x7/x8/x41/1634/828/x313 megaTinyCore for the megaavr ATtinies - Board Manager:
http://drazzy.com/package_drazzy.com_index.json
ATtiny breakouts, mosfets, awesome prototyping board in my store http://tindie.com/stores/DrAzzy
AlbertHall
I measured resistances from the bare Nano pins to both supplies:
          +5V      0V
D10    11M      inf
D11    230       560
D12    57        345
D13    11M      inf
It certainly looks like D11 and D12 are borked.
